Please help
Old Jan 13, 2013 | 06:11 PM
Ntkinwing's Avatar
Default Please help
Hi all,i comd from hk,my car is 99 accord CF4 sir-t,i got the wire obd2b to obd1,its just plug and play normally?Anything i need to do,i read alot of post here,still dizzy,please help.Thanks alot
Old Jan 14, 2013 | 05:30 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Please help
Originally Posted by scubacamper
I don't understand your question.
So don't post?
The user has a CF4 Accord which isn't USDM. He has a conversion harness from OBDIIb to OBDI, most likely so that he can run an ECU capable of being tuned. He is clearly asking if there is any additional work that's needed to get the OBDI ECU to work properly on his system.
OP, if you've purchased a complete conversion harness for the ECU you should not need to replace the distributor. You will need a compatible ECU with at least a basemap for your motor or one that will run your motor (You've got an H22 of sorts? So the JDM P13 would likely work)
Old Jan 14, 2013 | 06:34 PM
Ntkinwing's Avatar
So,that's mean if i got p13 chipped ecu run in h22 will work fine?Thank you for your answer
Old Jan 15, 2013 | 05:15 AM
It should, the JDM P13 is an OBDI ECU that is used on the H22A. I had that for awhile before upgrading to a chipped OBDI P28 + H22A map on it.
gizmogwaii
Engine Management and Tuning
30
Mar 17, 2017 08:08 PM
Prelude900
Dec 22, 2014 02:50 AM
payndew
Sep 12, 2010 08:34 AM
creepy116
Dec 8, 2007 01:25 PM
RudeLude
Mar 6, 2006 06:29 AM
