Del sol blinker question
Ive got a 93 sol and both bulbs in my blinkers work when there normally on, But whenever i go to signal right my passenger side bulb goes out and the green arrow on the right in the cluster comes on and stays on till i turn the car off and do it again. So my question is why does the blinker bulb on the passenger stay on until i use it to signal? then it just goes off? Any idea's on what i can do? Thanks.
The turn signal bulbs generally have two filaments, one for the turn signal and one for the parking light/taillight. Be sure you are installing the proper double-filament bulb in the front and rear.
I think you have a double filament bulb installed where a single filament bulb belongs or a single filament bulb installed where a double filament bulb belongs.
On Civics, the front turn signal bulb has two filaments - the second filament is for the front parking light, which is a separate circuit.
On Civics, the rear turn signal bulb is a single filament bulb. In contrast, the two rear brake lights have two filaments because the second filament is used for the taillights, which is a separate circuit.
Verify that your bulb terminal patterns match with terminals in each bulb receptacle.
