Can This motor be saved!
Old Jan 13, 2013 | 08:17 AM
Mikes2000civicsi's Avatar
Default Can This motor be saved!
hey h-t,
i recently bought a crv(200k)(i know this is the civic forum,more exposure).it still ran but had a cracked radiator,had no power,and was mixing coolant and oil.here are some pics of the head after i took it out of the car,do they seem okay,like new headgasket and go,or just replace the motor,and if i do,can i replace it with the b20b to save money,thanks for the input
Old Jan 13, 2013 | 10:02 AM
LowBudgetBEe's Avatar
Default Re: Can This motor be saved!
Originally Posted by Mikes2000civicsi
hey h-t,
Take the whole thing apart and have everything checked at the machine shop. it looks bad
Old Jan 13, 2013 | 04:05 PM
Runnerdown's Avatar
Several details of those pics show that the engine has been overheated badly. It's needs a thorough rebuild, a used b20 is much cheaper and easier at this point. I'd call hmotorsonline.com and get one.
Old Jan 13, 2013 | 07:25 PM
98vtec's Avatar
moderator emeritus
you need to have the surfaces measured on the head and block as well as the cylinder walls. Enough deformation of the cylinders will require new sleeves or possibly a new block depending on how hot it really got and enough warpage in the head or deck can ruin a motor
CivicEX97*
Feb 25, 2018 06:33 PM
JDM_Punk
Mar 26, 2010 04:08 PM
lunchboxEF91
11
Nov 24, 2004 09:15 AM
Mentat Ghola
Nov 19, 2004 03:04 PM
