Manual Window Regulator Repair?
Okay, ive been having a rough time roll my window up lately on my 99 Sedan (drivers side) and today it gave out. I wont be able to find one locally for sure and I already purchased this a year ago secondhand. I opened it up to do repairs but not quite sure how it all works out, any help regarding the internals or at least some photos of an opened regulator?
Front or rear?
Be sure to lubricate the rubber side channels with silicone lubricant to prolong the lifespan.
I don't think repair of the sedan-style cable-driven regulator would be easy.
Front driver
Im aware of lubricating, but i took the assemembly apart and it was all off track and the cables popped out.
It looks doable, just hoping somebody may post a picture or guide me as to how theirs looks.
I suppose I forced cranked it to pull up and ended up getting the cable loose from the window track which then loosened the cable in the crank assembly.
Im hoping that if i can get some better visual of a manual driver sedan regulator And/or internals I can fix mine and then make a tutorial or diy fix thread on it.
Any obvious cable fraying or broken parts?
I could be screwed if i did that. The fins for the inner gear are a bit frayed but i suppose something could be done there, i wish i kept my old regulator which my parents had me dump, damnit. I may have repaired it, just put it back together, going to test it
Ah, true true.
Well, I put it together, and cranked it a few times. Seemed good, until I installed it into the car and it broke again.
Apparently, there's a certain positioning for the gear and spindle and the cables which require a certain amount of torque....
Just my luck, somebody posted a Civic part out an hour ago, and I asked him to part out the regulator for $25.
jdmztrane
11
Jun 23, 2010 08:04 PM
strictly.business
15
Nov 28, 2006 11:20 AM
