delete
Old Jan 12, 2013 | 05:55 PM
InTheZoneAC's Avatar
Default delete
delete
Old Jan 12, 2013 | 06:01 PM
Former User's Avatar
Default Re: IAT Sensor Swap, need help with wiring
The connector will define proper polarity. What car/engine/OBD?
Old Jan 12, 2013 | 06:20 PM
Default Re: delete
after lots of searching, the wires pair up on either connector the same
The top pin, the side where you push the release on the connector is the signal, bottom pin is power. This applies to both connectors
I just wanted to be sure since I didn't have a way to check for signal/power on an already connected older style iat sensor.
Breckyp123
Honda Civic (2001 - 2005)
Sep 17, 2018 07:24 PM
Seth Wood
Sep 15, 2014 07:22 AM
CRX91SE
Jun 19, 2011 02:08 PM
ketchup
19
Sep 30, 2009 02:44 PM
enabi
Jun 19, 2002 07:54 AM
