high map at idle
I'm troubleshooting a weak idle/stalling in a 98 LS 5 speed, and my datalogger indicates a very high manifold pressure at idle (470-500 mbar). Anybody know what could be causing this? Am I correct in assuming it is a vacuum leak upstream of the IACV?
Edit: I believe the MAP sensor is functioning correctly as it indicates a correct pressure with the engine off.
Bump -- anybody know what could cause a very high manifold pressure at idle? I'm not even sure how the car could maintain a low idle with so much air in the manifold.
88crx-si
Nov 9, 2005 07:01 AM
civicracer1993
Feb 24, 2003 07:25 PM
