1991 accord miss fire
Old Jan 11, 2013 | 10:53 PM
alpinac1's Avatar
Default 1991 accord miss fire
Im sorry if this is already posted
I have checked and got nothing on this subject
I own a 91 accord ex coupe with a 5 speed, mileage is 160k
It is not firing on number 2 cylinder-
It has been running this way for a while from what I'm told ( just got the car )
It does not smoke or over heat- just sounds like a Subaru when running, i do know its the number 2 cylinder, head gasket, tune up????
Any input would be great-- thanks
Old Jan 12, 2013 | 07:34 PM
92 civic ex 4dr's Avatar
Did you check for spark? If there is no spark in just that cylinder i would replace the cap, rotor, wires, and plugs.
Posted from Honda-tech.com App for Android
Old Jan 12, 2013 | 08:37 PM
alpinac1's Avatar
Default Re: 1991 accord miss fire
have not yet checked for spark yet- cap looked good as well as the rotor
sounds like no compression when i start it- but it does run
just on 3 cylinders- no oil in the water or over heating
Old Jan 12, 2013 | 09:35 PM
koco's Avatar
Default Re: 1991 accord misfire
How do you know it's the #2 cylinder if you haven't checked for a spark? Is the spark plug fouled or something?
Use a long screwdriver against your ear to listen to the injectors working, and see if they all sound the same.
A compression test would be very important to diagnose this problem.
Old Jan 15, 2013 | 11:19 AM
alpinac1's Avatar
I pulled the #2 spark plug wire while it was runnung- it didnt change the way it ran-
if i pull 1, 3 and 4 the car will die
Old Jan 20, 2013 | 10:12 AM
OC Blip's Avatar
Follow the wire from spark plug to cap pull off of distributor while running (don't pull coil wire it will shock the $?!! Outa you trust me) if no fire replace plug no fire replace wire if still doesn't fire replace distributor if still no fire check compression although it should fire regardless of compression if new plug fires then goes bad check injector make sure you have fuel and lastly the three rules my dad always told me fire, fuel and compression car won't run without 1 of three that has nothing to do with your problem but easy to remember when you run into problems and check your gas cap make sure it seals properly could of got water into # 2 and fouled plug
Old Jan 20, 2013 | 10:14 AM
OC Blip's Avatar
Oh an when you pull wire off distributor leave close enough that the spark will jump from wire to distributor
Old Jan 20, 2013 | 01:22 PM
alpinac1's Avatar
So i got a code off it- its 74 miss fire # 4???
WTF
Old Jan 20, 2013 | 03:42 PM
OC Blip's Avatar
New plugs n wires
Old Jan 21, 2013 | 08:01 PM
alpinac1's Avatar
Think that will do it?
I wasn't thinking about checking the timing belt
Though I'm not that great when it comes to that type of stuff
I did pull the wire from the cap while it was running and there was spark from the dizzy
Pudnite
Feb 11, 2018 04:46 PM
f20beme
Apr 16, 2015 04:27 PM
Chargerhemi06
17
Sep 29, 2014 06:44 PM
Ct93CB7
Nov 26, 2010 07:19 AM
civicxxman
Apr 27, 2008 01:52 PM
