civic help
I have 2 qestion 1. does anyone know where the brake pedal springs connects on the steering clounm or have any pics. 2. i have a b18a1 and the throttle is loose i dont know if its connected wrong on the gas pedal or what. If anyone has some pics id appricate it need the help
Brake switches are usually adjustable. They can be screwed in or out depending on where you want the lights to come on.
As for the brake return spring, the locations where they attached should be noticeable. Look for loops and/or a small hole.
Again, the MM&Y and trim level, auto or 5 speed, would speed things up considerably.
I will have to assume, you have a 94 Civic and it's a 5 speed... #20
http://www.hondaautomotiveparts.com/...catcgry5=PEDAL
As mentioned brake switch may be adjustable if needed, it may not be making contact because of missing return spring, [lift pedal to test].
If not one of the above, brake pin switch "plug" is missing/broken. 94
Mooie Telebogen
Suspension & Brakes
Jul 15, 2016 11:23 AM
Kdeezy95
11
Nov 10, 2013 10:20 PM
