Removing panel to get at SRS fuse
Hi
I'm trying to remove the plastic panel under the steering wheel of my 2001 civic. I only see two star head screws but something is still holding it. Anyone any ideas how to remove this ? Also if I do manage to remove it ,will the yellow airbag fuse be located here?
Thanks in advance.
Thanks in advance.
Do you mean the steering column covers? There are 3 screws on the bottom and the top piece just pops off.
Before helping you with the SRS system you need to tell us what the problem is. Did the airbags deploy? Is the SRS light on? Was there recent work done to the car?
*DO NOT mess with the SRS system until after you disconnect the battery and wait AT LEAST 3 minutes before working.
And finally, this is all assuming you have a 7th gen Civic (2001-2005). Read this before posting: https://honda-tech.com/forums/honda-civic-2001-2005-78/faqs-guidelines-read-before-posting-2101211/
