Tial | GSR | LSVTEC | Type R | Greddy | TurboSmart
Old Jan 10, 2013 | 06:35 PM
ryguy2588's Avatar
Default Tial | GSR | LSVTEC | Type R | Greddy | TurboSmart
I have some more parts that I'm not going to use that I'm trying to get rid of.
The wastegate was installed on a car for 10 minutes and taken off. No exhaust has gone through it, and it comes with all of the bolts, the firing ring, and the springs is a 0.6 bar spring.
- Tial 46mm Wastegate: $350
- The high compression LS block is freshly built and was ran for no more than 20 miles. I took the head off to replace the valve springs. This block will be very good for any LS/VTEC or LS build. I have the LS/VTEC conversion kit for it if you are interested in that as well. Here's what it has
Machine Work:
Hot Tank
Hone
Polishing Crank
Recondition Rods
Recondition Pistons
Hone Rods
Install Pistons on Rods
Block:
LS Rods
LS Block
ARP Rod Bolts
P30 Pistons
LS Crank
GSR Water Pump
NEW GSR Oil Pump
GSR Timing Belt
OEM Rear Main Seal
NPR Piston Rings
King Rod Bearings
King Main Bearings
King Thrust Washers
Gasket Kit
LS/VTEC Kit:
Golden Eagle Dowel Pins
Oil Sandwich Plate
Oil Fittings
Oil Line
Block: $600 with the LS/VTEC kit
This is a manifold made by our shop. It's a T4 Schedule 10 stainless manifold with a 38mm two bolt wastegate flange. We had this on our race car, and it has held everything from a 6265 to our S372 without any crack or issues. We made 800+ whp on this manifold. We're going front mount now.
This is the thread with the car it was on and some pictures of it installed.
https://honda-tech.com/forums/showth...orado+race+fab
$500
Text me with any questions you have at 719-238-6833.
Old Jan 11, 2013 | 09:10 AM
ryguy2588's Avatar
Default Re: Tial | GSR | LSVTEC | Type R | Greddy | TurboSmart
Up!
Old Jan 11, 2013 | 08:38 PM
ryguy2588's Avatar
BOV is sold. ITR cams and GSR head are pending sale for tomorrow!
Old Jan 12, 2013 | 01:00 PM
ryguy2588's Avatar
GSR head and ITR cams are sold!
Old Jan 12, 2013 | 02:13 PM
EFnCRX's Avatar
Sick ******* parts man!
Old Jan 12, 2013 | 03:40 PM
ryguy2588's Avatar
Thanks! They need a new home!
Old Jan 12, 2013 | 09:38 PM
ryguy2588's Avatar
ttt
Old Feb 8, 2013 | 10:05 PM
ryguy2588's Avatar
Let's get this stuff sold!
98GSR-Turbo
Oct 14, 2008 09:22 AM
andrewk
Oct 31, 2007 04:15 AM
EFin' Kyle
Sep 22, 2004 04:19 PM
tnsxsear1
Feb 8, 2004 03:33 PM
