Which path is safer for 12 psi?
Old Oct 20, 2002 | 11:51 AM
Andrew 825SM's Avatar
Default Which path is safer for 12 psi?
Should I use 450cc injectors and run the vafc hack or use 450cc injectors with vafc along with a 4:1 fmu?
Old Oct 20, 2002 | 11:53 AM
Charlie Moua's Avatar
Default Re: Which path is safer for 12 psi? (NHB Fighter)
hondata
Old Oct 20, 2002 | 11:55 AM
Pelican's Avatar
Using both, you might run into some pretty rich fueling issues, especially top end. I Suggest one or the other.
Except, I just read the title again, VAFC hack is only Technically good up to 11 psi cause that's all the MAP can take.
So FMU might be better. Tuning might be a bitch with both.
Old Oct 20, 2002 | 12:06 PM
SpeedMonkeyRacing's Avatar
proper tuning (standalone)
Jeff-
Old Oct 20, 2002 | 12:11 PM
Quaalude's Avatar
Default Re: Which path is safer for 12 psi? (Corporal-Jeff)
450's and standalone
Old Oct 20, 2002 | 12:43 PM
ion_four's Avatar
Default Re: Which path is safer for 12 psi? (Quaalude)
you guys are ****. he didn't ask "should I get a hondata?"...
The afc hack without an fmu is better. Besides, you'd need an inline pump to run the 4:1 fmu and 450's, (that would be around 80-90psi atleast).
Old Oct 20, 2002 | 01:01 PM
Default Re: Which path is safer for 12 psi? (ion_four)
lol...yea i would get a hondata, but i dont have the money right now. I'm obd2 i have to convert to obd1 so hondata gonna cost me a grand which is too much.
Old Oct 20, 2002 | 02:06 PM
Etylorcen's Avatar
If you want power do it right...unless you have the money to rebuild.
Old Oct 20, 2002 | 10:44 PM
1.8T_EG's Avatar
Default Re: Which path is safer for 12 psi? (Etylorcen)
rx7 550's and the vafc hack... ((the 550s will allow you to run higher boost -- even greater map cut to compensate for even larger (makes sense if you understand the theory behind the hack) ))
Old Oct 21, 2002 | 08:36 AM
TeStUdO's Avatar
Default Re: Which path is safer for 12 psi? (1.8T_EG)
i agree with the hack and 550 injectors, it will let you run the higher boost with the map cut. im suprised someone else uses the rx7 550's
Throwdown
Jun 22, 2006 05:55 PM
MooreBoost
Aug 9, 2003 08:39 AM
IloveNewt
Jun 26, 2003 07:35 AM
First Gen Man
Jan 8, 2003 12:15 PM
Evil EG
May 25, 2002 12:14 PM
