Exedy clutch kit
For some reason when my clutch disengages (I push the clutch pedal) I can hear just one click almost like a slap. After the click, with the clutch pedal held down, you can hear what reminds me of a grinding or cycling type noise. The clutch works just fine, there is no slipping. But the sounds are annoying and I believe I will need a new clutch soon. I've already replaced the clutch master and slave cylinder. Here are my questions:
Do these sound related to the clutch or flywheel?
What is your opinion on this Exedy clutch/flywheel kit?
For a daily driver is it best to go with a 12lb flywheel or this lighter 9lb flywheel?
Is it a decent price?
Exedy clutch kit / racing flywheel
Ok. I know when my throw out bearing went, It will squeal when i press the pedal.(7 months ago)
As of right now, my car is making a clicking noises and some odd sounds when pressing the pedal just like you. For my problem I am assuming its my bolts that are loose b/c my troque wrench went out the day i was installing my clutch. I will be dropping the tranny on Friday. i can let you know then.
Besides that, the clutch kit seem to be a good kit. You can get it cheaper on ebay.
http://www.ebay.com/itm/EXEDY-CLUTCH...4b860d&vxp=mtr
best clutch right there lol installed that clucth setup 2 years ago when i assembled the motor, been superchargered and currently pushing 300WHP on that clutch and its still holding haha.
Exedy OEM or Stage 1 is your best bet. Stage 1 has a slightly heavier pressure plate for better grabbing power, but uses the OEM clutch disk. So you retain essentially all of the OEM drivability without the drawback of a "race" clutch. Stage 1 also has a better TOB, if you bang on your clutch a lot stage 1 sounds like a better alternative.
As for the flywheel, the 12 pound flywheel is a good medium between the OEM and the 9 pound. Having slightly more weight than the 9 pound should benefit you when you're crusing around town. Less focus on Rev matching, which means you can be a little sloppy without jerkyness.
I also like the stage 1 better than OEM replacement, even for daily driveability. The OEM is too soft IMO.
My preference is for the lightest flywheel possible. I have a 7 lb. and I wouldn't go heavier. I find it smoother than heavier, more sluggish flywheels. The wife feels the same.
Well I was able to get some very useful information out of this thread. I appreciate all of your comments and you have helped me to make a decision, thank you! Is the Exedy flywheel Ok or should I look towards a different brand? I've read good things about the Fidanza.
Exedy is a great company and I have had no problems with my Fidanza. You'd be safe either way. The hard part will be figuring out which weight you think you will prefer.
Heinz57
16
Dec 29, 2005 07:00 PM
