Function and form type 1 on efs
Hi Im looking for a ''stance'' suspension I found at the function and form type one but I checked some posts and people say that the front doesnt wanna go in the fenders so, what should I look for? I will use 9.5 and 8.5 rims so i need it low
Koni Yellows with extended top hats and either find some used lowering springs for cheap, or spend some dough and get the Ground Control sleeves/springs.
Koni Yellows with cheap lowering springs and Ebay extended top hats ~ $600?
Koni Yellows with Ground Control sleeves/springs/tophats ~ $1000
Why not just fully stance out your car and simply cut the springs.
Very cost effective and gives you the same poor drivability issues that you would have if you spent money.
Nah it wont I atm have cut springs and it sux badly hehe Ill need it stiff cause I wont want my wheels to reach fenders
I just need some of your setups and photo if you have. Thx for the build F22 Lfm!
I guess that kit is a good one but it seems like theres missing parts
top plates.. http://www.ebay.com/itm/4525-01-Grou...ee3907&vxp=mtr
Yo I wont pay 700 just to try it out Im checking peoples comments and they say that its not giving a nice reault at the front. So I can use oem top plate on koni yellow with ground control top plates?
FF1s wont get it right. FF2s will. but the cost outweighs the gain.
"stance" is cool and evrything, but all it really gets you in the long run is a car with tires taht are bald on the inside and crappy handling.
koni yellow, cheap springs, and gc top hats are what you need if youre on a budget.
Slamming an EF on a budget wont really happen. FF coilovers will not get the car low. Period. They will slam just about every other chassis, but not the 88-91 civic/crx. You need to look at Ground Control coilovers with custom spring rates (500 lbs+) for the front, shorter springs and set on the lowest perch of the Koni shock body and either Ground Control or custom upper mounts (top hats) to retain some shock travel. To fit the widths you are speaking of you will need at least a camber kit for the rear to go beyond the negative camber when you slam your car. Possibly even a front kit depending of the offset and how much you want to tuck. With the front kit, you greatly increase the chance of your UCA hitting the shock tower...now you need to cut holes in your towers. This is like black magic for EF's...you cannot just slap on coilovers and dump. Sorry.
Or you could just get ebay sleeves, oem struts and bounce on down the street.
Hahaha yeah bouncing on ground is what I do atm
Ill probly go for koni yellow struts and ground control coil and sleeve with oem top plates
But i would suggest finding someone on here who modifies stock top hats. You are GOING TO NEED extended top hats if you dont want to continually bottom out your $500+ Koni's... Should be able to find a decent set of 4 for $50?
Yeah Ill try to look at it
I found 4 koni yellow wich were on an integra 2000 for 400 but I think theyre too long :S am I right?
Looking at the model #'s:
One pair are the same, the other are different.
Whether its the front or the rear that are the same, idk.
But here is a full brand new set for $503 with free shipping.
http://www.tunersports.com/koni-spor...ort_p2154.html
Awsomeeee thx for that link :D Ill mail them to know how much would cost the shipping to canada quebec since free shipping is only for lower 48 states
