Best Way to Remove Paint from Engine Block/Head
Old Jan 8, 2013 | 12:02 PM
turboHondaWesJ's Avatar
Default Best Way to Remove Paint from Engine Block/Head
Cross post from Paint/Body:
The title says it all; what is the best way to strip the paint from the head block? The previous owner painted the longblock black (and did a subpar job; it's flaking and generally looks awful). Can I just tape up sensors/etc and spray the longblock with Aircraft Stripper™? TIA
-Wes
Old Jan 8, 2013 | 12:07 PM
mechanix619's Avatar
Default Re: Best Way to Remove Paint from Engine Block/Head
Aircraft stripper or even brake cleaner.
Old Jan 9, 2013 | 09:36 AM
raverx3m's Avatar
it will strip the oil pan unless its removed.
Old Jan 10, 2013 | 09:16 AM
Psychoteen101's Avatar
If the paints flaking, a pressure wash or steam cleaner might do the trick as well
Old Jan 10, 2013 | 09:24 AM
GagnarTheUnruly's Avatar
Aircraft stripper does a great job on paint but kiss your gaskets goodbye. I'd keep it away from electrical wiring, too.
Old Jan 12, 2013 | 06:58 PM
grimee21's Avatar
good idea
Old Jan 21, 2013 | 01:10 PM
Ear'sEgFerio's Avatar
AirCraft remover and Dollar General Oven cleaner does wonders. WEAR GLOVES
Old Jan 23, 2013 | 09:17 AM
Clean Creations's Avatar
Buy a cheap sandblaster, the kings that hooks up to a regular air hose, I would tape up anything you don't want messed up with some aluminum tape
Old Jan 23, 2013 | 10:06 AM
92civiceg9gsr's Avatar
Do not sand blast the motor in the car. In fact don't sand blast any motor you ever plan on using. Media blasting is different story. Pressure washing, paint thinner, wire brush are the way to go for a clean job.
Old Jan 23, 2013 | 04:40 PM
89B16CRXHF's Avatar
Aircraft stripper is easy to use, brush it on wait 30-45 min. Clean off. Use a heavy degreaser like purple power from walmart or home depot works the best, for the crappy "green products" but its the best.
TB123
Paint and Body
Aug 2, 2013 09:14 AM
turboHondaWesJ
Paint and Body
Jan 18, 2013 02:29 PM
bubba cola
Paint and Body
25
Mar 4, 2009 04:36 AM
ampm
Paint and Body
May 2, 2007 05:16 PM
xxxmikenicexxx
Dec 31, 2005 07:47 AM
