How To Remove VHT Paint From Engine/Head/Tranny?
Old Dec 26, 2005 | 09:09 PM
xxxmikenicexxx's Avatar
Default How To Remove VHT Paint From Engine/Head/Tranny?
Hey guys, hows it going? Thought I would ask if someone knows how to do this. I painted my block before and now I need to remove the paint from the tranny/head/block so I can try to clean it so it looks nice without paint or at least paint it better if I have to. I am unsure what will work well and what is safe for the aluminum. If someone could help me out I would really appreciate it. I used VHT 1500 degree aluminum paint also. Thank you in advance.
Old Dec 27, 2005 | 02:32 AM
rebo0t's Avatar
JASCO or Carb Cleaner
Old Dec 27, 2005 | 07:21 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: How To Remove VHT Paint From Engine/Head/Tranny? (xxxmikenicexxx)
paint stripper aircraft remover works well
Old Dec 27, 2005 | 11:16 AM
splitime's Avatar
Default Re: How To Remove VHT Paint From Engine/Head/Tranny? (PURPLETERROR aka BIGMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">paint stripper aircraft remover works well</TD></TR></TABLE>
Comes in a spray can at autozone/pepboys (can't remember which) and it works well.
Old Dec 27, 2005 | 01:53 PM
Default Re: How To Remove VHT Paint From Engine/Head/Tranny? (splitime)
Yeah Ive used the stuff on a couple valve covers. But I do know the stuff is bad for aluminum, which i dont want to risk on my engine. Is there anything else/anything anyone has experienced similar to my scenario? And thank you guys for the responses.
Old Dec 31, 2005 | 12:27 AM
Vsm Hatch's Avatar
helped a friend put a motor together that he painted. We used plenty of brake clean to in the process and got it all over the freshly painted block and the paint juss melted off the block.
you should give it a try
Old Dec 31, 2005 | 07:47 AM
I definitely will, thank you so much for the input.
DOHCgarage919
Sep 3, 2007 05:31 AM
JDM RHD eg6
13
Nov 20, 2006 10:08 AM
MassScene
Mar 15, 2005 05:26 AM
trooper0641
Oct 11, 2004 12:48 PM
itr1244
Aug 30, 2002 02:46 PM
