single state urethane without primer
Old Jul 30, 2013 | 09:07 PM
TB123's Avatar
Default single state urethane without primer
I have an engine block that I want to turn into a coffee table. I plan on painting it with a single stage metallic paint from Summit.
What will the outcome be if I skip priming and paint over the bare metal/factory paint (this is an iron VW block). It's going to be indoors so I figure it won't need to be as durable as a vehicle finish, but I also don't want the paint to chip off if I touch it.
Old Aug 1, 2013 | 07:42 PM
Rukusmasta2's Avatar
Default Re: single state urethane without primer
get it blasted somewhere quick probably like 40-60 bucks and then just spray it. if not just pressure wash it real good use some purple power and then some brake kleen. run thru it with a red scuff pad and the spray.
Old Aug 2, 2013 | 09:14 AM
Hidenplanvew's Avatar
Well there is a product called No sand Its a gloss remover (most Automotive Paint supply places have it) .. I painted a motor for Gates belts for Sema and used single stage. Came out pretty nice, and even. When painting with a spray gun, you need to paint at about a 45 deg angle and make sure you get all the nooks. If you use chemicals to clean make sure you flush it with plenty of water and make sure you get all the grime and such off.
DingoAteUrBaby
Paint and Body
Aug 8, 2010 04:37 AM
nico91civic
Paint and Body
17
Apr 13, 2009 05:47 AM
toojdmforschool
Paint and Body
10
Feb 12, 2009 08:52 AM
11secEk
Paint and Body
Dec 28, 2007 08:08 PM
mugencx
Nov 25, 2007 07:22 PM
