oil pump question
Old Jan 7, 2013 | 06:38 PM
jdaniels1869's Avatar
Default oil pump question
should the oil pump spin free if still on engine. 97 honda prelude
Old Jan 7, 2013 | 06:39 PM
Fliptard's Avatar
Default Re: oil pump question
crankshaft spins oil pump.
Old Jan 7, 2013 | 07:15 PM
my engine balance shaft blew out and i want to make sure its the oil pump that caused the problem before i take it off
Old Jan 7, 2013 | 07:16 PM
engine balance shaft belt
Old Jan 7, 2013 | 07:24 PM
v4lu3s's Avatar
RTFM
if your engine spins then your oil pump spins.
Old Jan 8, 2013 | 09:15 AM
98vtec's Avatar
moderator emeritus
to emphasize, your crank has a notch in it which lines up with the same notch on the oil pump. thus if one spins, the other spins.
Old Jan 8, 2013 | 01:39 PM
Fliptard's Avatar
How did you "blow out" your balance shaft?
Old Feb 13, 2013 | 02:32 PM
Dunckeldust's Avatar
i run without the balance belt its not NEEDED
Old Feb 14, 2013 | 11:14 PM
holmesnmanny's Avatar
The engineers are pretty smart. They put it there for a good reason.
Old Feb 15, 2013 | 02:12 AM
Deksinjo's Avatar
Engine code is ?
Old Feb 16, 2013 | 08:18 PM
To make your engine a little more stable & in balance. I can't even tell the difference on or off.
Page3905
Jul 4, 2012 07:56 AM
markb4081
May 28, 2008 07:36 AM
LordAphotic
Apr 12, 2006 11:32 AM
kurinto
Jul 14, 2004 05:52 AM
