97Accord hub to rotor bolt stripped HELP!!!
Old Jan 7, 2013 | 01:03 PM
B1Integra's Avatar
Icon2 97Accord hub to rotor bolt stripped HELP!!!
while i was changing my wheel bearing i kinda stripped a bolt.. the hub bolts that goes into the rotor....does anyone have an idea on how i can get that bolt out without drilling.....
Old Jan 7, 2013 | 04:24 PM
go-part's Avatar
Default Re: 97Accord hub to rotor bolt stripped HELP!!!
Lucky you.. the bolt isnt completly stripped.. just the corners arent as flat
http://www.sears.com/shc/s/p_10153_1...id=00952166000
^this would help you
If you wanted to you could make a slot deep enough for a flat head screw driver to fit. Then just unscrew the bolt
Old Jan 7, 2013 | 07:29 PM
v4lu3s's Avatar
RTFM
were you using a 12 point socket? if so stop doing that. i would try a good solid 6 point (impact preferred) socket and work it from there. that tool kit the other guy posted is nice, i have used a similar one with some success before.
Old Jan 7, 2013 | 08:11 PM
nanjay's Avatar
looks like you can still use a 6 point socket to get it out, if it doesnt work bolt extractor does wonders... gl
Old Jan 8, 2013 | 08:15 AM
B1Integra's Avatar
actually i used a 6 point socket but then kinda not align it too good thats probably why.....but i was thinking if i couldn't get it out i might as well weld a nut on and unscrew it.....
Old Jan 8, 2013 | 08:49 AM
TouringAccord's Avatar
H-T Order of Merit
I have a similar bolt/nut extractor set from Sears like the one go-part posted and the few times I've needed to use it it's worked great.
Old Nov 13, 2013 | 02:16 PM
Mishako129's Avatar
Will that kit work if the head is completely stripped? I have 3 of these bolts that are stripped out completely, I used an electric impact on them and they didn't budge.
Old Nov 13, 2013 | 02:20 PM
Mishako129's Avatar
So let me get this straight, you can't use that kit if the bolt head is completely stripped?
Old Nov 13, 2013 | 04:54 PM
BlackLude90's Avatar
Air hammer time.
Old Nov 13, 2013 | 05:23 PM
Mishako129's Avatar
Originally Posted by BlackLude90
Air hammer time.
I don't have an air hammer.
spidermancivic
Oct 5, 2006 10:10 PM
spidermancivic
Oct 3, 2006 09:41 PM
JDM978
Oct 1, 2006 06:30 PM
hellas
Jan 21, 2003 12:33 PM
StinkyTofu
Jan 15, 2002 10:56 PM
