04' TSX Not Starting-Fuel Pump Issue?
Sooo, my car's not starting! FML!!!
Ok, well as you see in the vid, it does actually turn on. However, it's almost like the engine is not getting a steady supply of gas to stay on. I've checked the fuel-pump fuse, reset the battery, and still no-go. If anyone has any suggestions, I would LOVE to hear from you:D
Either the fuel pump itself is bad or more likely it is a problem with the PGM-FI Main Relay, a common Honda problem...
http://techauto.awardspace.com/mainrelay.html
However it can also be a few other things, maybe a bad FPR, ot even just a bad connection someplace...
http://www.tsxclub.com/forums/conten...y%20System.pdf 94
SatanicMechanic
Mar 4, 2010 07:09 PM
