?crx obd0 b16 swap?
Old Jan 5, 2013 | 09:19 PM
Freek's Avatar
Default ?crx obd0 b16 swap?
hey guys just picked a 89 crx si with obd0 b16 swap. running pw0 ecu. acts like its in ssafe(limp) mode. iacv needs changed surges but no check engine light vtec will not kick in at all. rpm wont pass 4g just curious on any ideas. gonna change iacv tomorrow.
Old Jan 5, 2013 | 09:27 PM
F22Master's Avatar
Default Re: ?crx obd0 b16 swap?
Any codes from the ECU? Check your TPS, mine went into limp mode with it not working properly.
Old Jan 5, 2013 | 09:31 PM
Freek's Avatar
no cel it popped 17 when we pcked it up but it was the speedo cable noy all the way in fixed that today. no cel since
Old Jan 5, 2013 | 09:41 PM
F22Master's Avatar
Do you have access to another ECU?
What is the max you can rev?
Old Jan 5, 2013 | 10:07 PM
Freek's Avatar
4000 rpm
Old Jan 6, 2013 | 02:31 PM
v4lu3s's Avatar
RTFM
after teh code 17 did you reset the ecu?
umair
Mar 2, 2015 03:51 PM
bayron
Nov 16, 2008 05:14 AM
s2000june
Jan 1, 2005 07:43 AM
dropd4door
Apr 5, 2003 03:27 AM
2k2silvertype-s
Feb 12, 2003 07:22 AM
