Axle broke, now no gears, and weird noises
Old Jan 5, 2013 | 11:49 AM
LS-turboner's Avatar
Default Axle broke, now no gears, and weird noises
my friend has a 98 ls. he isnt a car guy, so sometimes he is neglectful. He turned a hard left, and his passenger side axles outer joint grenaded. he heard a loud pop, then the sound of bearings scattering.
he said he lost all gears, the clutch wouldnt stall the engine, but it would make it drop in rpms when you release the clutch, so it seems its making contact.
when we went to get the car, we put in a new axle. still no gears, no nothing. when we pushed the car out of the lot, we heard horrendous popping, clanking, and grinding for a bit. it felt like it binded up, and then released. horrible sounds though, and it definitely sounded like it was coming from the trans. he said the shifter felt weird too, like it wasnt going all the way in to any gears. also, when we pulled the axles and trans, there was hardly any fluid in it.
we pulled the trans, is there a way to see if its messed up without crackin the case? my poor friend is on a budget, so we are trying to figure this out, if the trans isnt fucked, we would like to reuse it, but thats a long shot. i should have troubleshot before we pulled it, but hes desperate.
will an axle breaking grenade a trans like that? could it be a clutch issue?
thanks guys
Old Jan 5, 2013 | 04:38 PM
fcm's Avatar
fcm
Old Fart
Default Re: Axle broke, now no gears, and weird noises
The transmission, at least the differential is toast, you will need to pull it apart to repair anyway, you will not know the extent of the damage untill you do pull it apart, may be easier to just find a used LS transmission. 94
Old Jan 5, 2013 | 05:58 PM
Hidenplanvew's Avatar
I would look for another trans and just set the broken one aside
Old Jan 6, 2013 | 11:55 PM
JOE_DC4ever's Avatar
You can crack the case without too much effort or added expense. And if you havent done it before consider it good practice since you wont lose anything by taking a look to see what you busted
ksnRock
Transmission & Drivetrain
May 15, 2019 07:34 AM
New Fella
Aug 6, 2013 08:03 PM
ari_one
Jan 5, 2011 10:18 AM
gt30rintegra
Jul 1, 2008 10:53 AM
turbocivic0618
Oct 10, 2005 10:53 AM
