AL fuel hardlines, experiences?
Hey guys.
Well I am in the process of putting AL hardlines on my car. I am aware of the issues that come along with that, and I also know that quite a few people have no issues at all with them.
-Car will be running on ethanol (E98) and will get flushed with 93 before prolonged sits (2 weeks+)
-Lines on body will all be supported with cushion clamps every ~12". All connections will be hardline except for the body to motor span. Fuel cell, fuel pump, and filters are all going to be solid mounted to the car, no straps.
-Fuel rail lines are all supported from the motor and are under 12" total.
Is what I have done correctly limiting the chances of cracking due to vibrations? Would you do anything differently? I do not want to run braided lines beyond what I have now.
I do not think the tools I have are capable of bending stainless in these sizes, that's mainly why I am sticking with AL for now. Input is appreciated.
Is the regulator mounted to the body? Personally off at all possible I'd try to mount the reg on the power plant so you wouldn't have to worry as much about the engine vibration vs body vibration
so long as everything in relation to the hardlines is moving at once, you should have no problem. since your reg is bolted to the motor, the lines will never be under any strain
Honestly, I have no idea where they are getting a 25-35psi rating for aluminum tubing. Stuff, in the same thickness, is rated for 1300psi in aircraft applications. Even if it's a lower annealing it will still hold a hell of a lot of pressure. New cars use plastic fuel lines now, lol. Burst under high pressure is not at all a concern.
Either way, speedwaymotorsports sells the same thing that JEGs/Summit sells, rebranded of course, and it's rated for 250psi.
http://www.speedwaymotors.com/Alumin...-OD,34277.html
Thanks for the help guys, onward with my project lol.
If you used at least 0.035" wall thickness 6061 aluminum, it will be good for at least 100 psi with a significant safety margin.
Fighter jets use 0.028" in most of the lines that size and will run those tubes up to ~130-150 psig with a small safety factor. That's including structural vibrations and material fatigue of 8,000 flight hours. So once you get to 0.035" wall thickness in a ~1/2" size, you're golden on any fluid in a car.
Who is Mr Robot?
how hard are you finding it to bend tight radius pieces without crimping/collapsing? I'm about to start on something like this as well
Let me put it this way, if you don't have a bender, it's going to collapse and kink. Your bender is going to dictate your radius, and the tight radius large diameter tubing benders are $$$.
Soooo my advice is give yourself room to make normal bends lol.
NA.GEORGE
Sep 13, 2005 06:28 AM
