Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
03 civic ex overheat/transmission problems won't start!!!!
Old Jan 5, 2013 | 09:50 AM
blob's Avatar
Icon2 03 civic ex overheat/transmission problems won't start!!!!
Was driving fine. Then one day it over heats I put some water in and kept driving. No problem. Happened again did the same thing no problem but this time I flushed the coolant system. Overheated one more time but this time it was all bad. It over heats then the tranny started to buck hard. Took it home replaced the thermostat and hoses. Started up again to fill the coolant up while the car was idle and it just dies out of no where. And a crazy clicking sound was coming from the bellhousing.all transmission lights are blicking. On the dash. What the heck has happened to my car. Please help. Mind you the tranny does not start making the clicking sound until the car key is set to acc or on. But the car turns but it doesn't start.
Old Jan 5, 2013 | 07:23 PM
toyomatt84's Avatar
Sanji
Default Re: 03 civic ex overheat/transmission problems won't start!!!!
Check your transmission fluid for discoloration. Sadly, I think there may be some serious internal damage to the engine. It sounds like you might have blown the headgasket then it caused some other failures.
Old Jan 6, 2013 | 11:30 PM
backjack's Avatar
hi, im new here but i think someone out there can help me. i own a 2002 honda civic vti-s matic transmission. i got it from sister who did not pay much attention in having it maitained properly. it overheated, i changed the gasket twice yet the problem stays the same. i already drained the water and coolant and used purified water in the rediator, yet same problem existed. please help what to do.
Old Jan 7, 2013 | 10:56 PM
blob's Avatar
I figured the head gasket is done. But compression is good. I don't get it. Damn car. Well I'll check the fluid tonight to see if it's discolored. If it is what does that mean exactly. When I did the tranny flush in the beginning of the year, 2012. I used Honda Genuine. I know the trannys in this generation are garbage. Recalls and shady stuff like that.
delslow45
Jun 2, 2010 01:53 PM
tpot90
Jun 14, 2009 04:24 AM
zam-pa-te-es-te
Oct 9, 2005 03:32 PM
CaseyGT
Oct 11, 2004 10:31 AM
Fatty_1775
Jul 17, 2003 11:10 PM
