Moroso Oil pan capacity question?
Old Jan 4, 2013 | 12:18 AM
93grayeg's Avatar
Icon2 Moroso Oil pan capacity question?
Car I bought has a Moroso oil pan on it, Motor is a darton sleeved GSR, Not sure which pan it is , I was never told. Should I just start out with 4.5 qt and keep checking the dip stick? Thanks guys!
Old Jan 4, 2013 | 03:04 AM
Turbo-LS's Avatar
Default Re: Moroso Oil pan capacity question?
really? just like any car check it
Old Jan 4, 2013 | 04:51 AM
grumblemarc's Avatar
The Grumpiest
Google.
Key Features:
Wet sump, 5.5 oil quart capacity (not including oil filter capacity), 6" deep
Compatible with all B-series VTEC & non-VTEC engines (B16-B18-B20)
Works with OEM exhaust manifold and most aftermarket exhaust/header combination's
Kicked out sump that increases oil capacity to 5.5 quarts
Includes 6 trap doors, 2 baffles, and removable sump tray that keeps oil contained in the pickup area during hard acceleration, cornering and braking.
Turbo/Supercharger oil drainback
Features a magnetic drainplug and temperature sensor bung provision
Clear zinc plating for durability and corrosion resistance
Uses stock OEM Honda oil pan gasket
Old Jan 4, 2013 | 09:00 AM
Spawne32's Avatar
I have the baffled 4 quart pan and i cannot figure out why for the life of me this thing takes somewhere around 4.75 quarts to get up to the proper level lol
Old Jan 4, 2013 | 10:45 AM
Turbo-LS's Avatar
is you dipstick tube installed all the way like stock? my gsr block i couldnt get it all the way down so i had to adjust where on the stick was full
Morhpeous
Sep 3, 2007 05:49 PM
hondaboy4life
Sep 29, 2006 08:01 AM
thegeorge613
Jul 31, 2006 05:02 PM
speedy108
Jun 30, 2004 06:56 AM
lilxvtecxpwr
Oct 9, 2002 04:12 AM
