Speedometer off by 10 MPH...
Old Jan 2, 2013 | 04:54 PM
cuyambro's Avatar
Icon6 Speedometer off by 10 MPH...
my wife had a new cluster put in and the mechanic of an idiot told her that it caught on fire by it self, then the RPM gauge is off as well and the light for the gas doesn't go on when low. Can any body help me out?
Old Jan 2, 2013 | 04:56 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Speedometer off by 10 MPH...
Take it back to the mechanic and have him put in a cluster that doesn't combust upon installation.
Old Jan 2, 2013 | 05:27 PM
dirty19's Avatar
Ridin Dirty in Cali
Spontaneous combustion of a cluster?
If the mechanic replaced it with a( new) one then a warranty is implied here.
Especially if it was new.
Take it back and have him re replace it with an even newer one.
Old Jan 2, 2013 | 05:46 PM
The Grumpiest
You could have done the work yourself for nothing and it would be working right now.
Old Jan 2, 2013 | 07:45 PM
doomi's Avatar
To clarify; did the new cluster ignite when she started the car, or did the old one burn then get replaced with a cluster that isn't working properly?
I have to agree. It takes longer to warm up the car to drive to the mechanic than it does to swap the cluster yourself.
Old Jan 3, 2013 | 03:08 AM
cuyambro's Avatar
I would of done it myself, but my wife did it as a present. would this cause my speedometer to stop working right? my wife wants to get me another that work, but I rather fix what's not working now. thanks guys
Old Jan 3, 2013 | 03:26 AM
The Grumpiest
So why are we NOT taking it back to the mechanic that screwed up the install in the first place?
Old Jan 3, 2013 | 03:39 AM
NVturbo's Avatar
O.G. triple O.G.
Don't tell me the idiot installed the cluster while the key was in the ignition. I would not even let him look at my car. It my self-combust upon viewing.
Old Jan 3, 2013 | 04:00 PM
cuyambro's Avatar
I can't take it back to that mechanic cause if I take it I'm fighting and my wife took it a long time ago; while I was on deployment.
Old Jan 3, 2013 | 04:04 PM
cuyambro's Avatar
I feel the same way guys trust me, I wish I had the answer for this idiot that worked on my ride and I would of told him to fix everything before me taking my car this way. SO!!!! rule of thumb for anybody out there: don't let your significant other do changes to your car you don't want done, keep your list of things to do to your self and only yourself.
Old Jan 3, 2013 | 04:30 PM
doomi's Avatar
Go to a local junkyard.
Pull new cluster for next to nothing.
Go home.
Disconnect battery.
Remove 4 (possibly 6?) screws.
Slide out old gauge cluster.
Remove electrical connector (3 I believe but can't recall for sure).
Reconnect in reverse order.
Have gauge cluster that works and doesn't ignite.
Old Jan 6, 2013 | 03:44 PM
cuyambro's Avatar
I'm still saying....is that the reason why my speedometer of??? if is the cluster i will go and buy and install it my self just like i have done with most of things on the car my self, but if is not the reason of my speedometer acting up then i much rather fix that first.
HELP GUYS!!!!
Old Jan 6, 2013 | 03:46 PM
The Grumpiest
Question. Was the speedo & tach off BEFORE you replaced the cluster? Answer this and you answer your own question. And maybe find out what actually caught fire, hm?
Old Jan 9, 2013 | 01:46 PM
cuyambro's Avatar
Thank you
bluestd
May 18, 2010 09:43 PM
aziaticvang
Jan 8, 2008 06:41 PM
roids87
Honda Civic (2001 - 2005)
May 16, 2007 07:52 AM
94eh2
Mar 22, 2007 06:18 AM
E-lude78
Jun 5, 2003 01:20 PM
