SYNCHROTECH *** DISCOUNTS & SPECIAL OFFERS ***
New Items In Stock and Ready to Ship !!
Synchrotech® Hardened B16A/B18C 3-4 Hub $50
Fitting: 1992-2001 GSR ITR B16 B17 (S80 Y80 YS1 Y21 S21 S4C)
http://shop.synchrotech-transmission...-ITR-SH120.htm
Synchrotech® 1-2 D Series Hardened Sleeve $99.95
Fitting: 1st/2nd SOHC Civic 1988-2000 (L3 S20 S40)
http://shop.synchrotech-transmission...00-SOD16-1.htm
Synchrotech® D17 SLW 5/R Hardened Sleeve $99.95
Fitting: 5th/Reverse Civic SOHC D17 2001-2005 (SLW)
http://shop.synchrotech-transmission...W-SO-D17-5.htm
Synchrotech Transmissions Inc [/LEFT]
Synchrotech® Hardened Sleeves $99.95-$149.95
B16/B18 1-2 Hardened Sleeve $149.95
B16/B18 3-4 Hardened Sleeve $99.95
B16/B18 5-R Hardened Sleeve $99.95
K20 6 speed 1-2 Hardened Sleeve $149.95
K20 6 speed 3-4 Hardened Sleeve $99.95
K20 6 speed 5-6 Hardened Sleeve $99.95
Y1/S1 1-2 Hardened Sleeve $149.95
Y1/S1 3-4 Hardened Sleeve $99.95
Y1/S1 5th Hardened Sleeve $99.95
H22 1-2 Hardened Sleeve $149.95
H22 3-4 Hardened Sleeve $99.95
H22 5-R Hardened Sleeve $99.95
H23 3-4 Hardened Sleeve $99.95
D16 1-2 Hardened Sleeve $99.95
D16 3-4 Hardened Sleeve $99.95
D16 5th Hardened Sleeve $99.95
D17 1-2 Hardened Sleeve $99.95
D17 5-R Hardened Sleeve $99.95
Synchrotech® Premium Brass Synchro Sets $149.95-$199.95
* Premium replacement for OEM brass synchros
* Improved lock angle
* Updated tooth pattern
Synchrotech® Pro Series Carbon Synchro Sets $199.95-$299.95
*Carbon Fiber Lining *Stronger Brass Body
*Improved Lock Angle *More Surface Contact
*Stronger Bonding *Improved Oiling
Synchrotech® Rebuild Kits (Carbon or Brass) $249.95-$399.95
Synchrotech® Master Rebuild Kits with Sleeves (Carbon or Brass) $549.95-$699.95
MFactory Helical LSD $684.95
MFactory Metal Plate LSD $899.95
MFactory Final Drive Set $579.95
MFactory 6 Puck Carbon Metallic Sprung Clutch Kit $399.95
http://shop.synchrotech-transmissions.com/MFactory-6-Puck-Carbon-Metallic-Sprung-Clutch-Kit-MF-TRS-08B16.htm
Honda-Tech discount price $355.50 + $15 shipping
http://shop.synchrotech-transmission...SK-SYN-YS1.htm
Do you have a good deal on a Rebuild kit for a b16a y21 transmission. need bearings, seals, and carbon syncros.
And a final drive 4.92 for the same transmission.
Price shipped to Norway would be good.
Thanks for any reply
Kristian
Kristian
Could you pm me the HT price for BSK-SYN109?
I'd like to ship my shafts down to you, whats the best way to do this? They're a bit heavy so I'm unsure if a box would make it? Will they be cleaned etc? I know the oil passages get clogged/dirty.
Also, MFactory makes a sealed ball bearing for the LSD in the H transmission, do you carry this, or recommend it over the tapered bearings?
Hi,
I need a gsr transmission that can support 350whp. I do not have a core. If you are able to help, please email me a quote and description to mxc1900@gmail.com
Thanks,
Mike
Thanks,
Mike
Hi,
Thanks,
Mike
Thanks,
Mike
Emailed a quote
You can send the shafts in two USPS flat rate boxes. Use a large FRB for the mainshaft and a medium FRB for the countershaft. Make sure to wrap each shaft in bubble wrap before boxing them. We will clean and inspect the shafts and call you with an estimate for the needed parts.
I do not think there are sealed ball bearings available for the H22 trans (at least none I have ever seen). We use the OEM tapered bearings.
In Stock and Ready to Ship!
(Dealers will receive 20% off the sale price)
http://www.shop.synchrotech-transmis...Series_c18.htm
B Series Master Rebuild kits: $699.95
Comming in March!!
Thanks for the great products.
