Intake/Compressor boost sources. Which to W/G, which to BOV
Old Jan 2, 2013 | 07:15 AM
Vagitarian's Avatar
Default Intake/Compressor boost sources. Which to W/G, which to BOV
Hey guys, just curious ihow I should be routing my lines. I have 2 available boost sources for my external wastegae and my bov. One source is a large vacuum nipple off the intake manifold, and the other is the nipple on the compressor housing.
Which of those sources should I use for the bov and which for the wastegate/manual boost controller lines
Thanks alot
Old Jan 2, 2013 | 07:26 AM
TheShodan's Avatar
Moderator
Default Re: Intake/Compressor boost sources. Which to W/G, which to BOV
You have options..
http://www.tialmedia.com/documents/w..._wginstall.pdf
Many use both methods.
Old Jan 2, 2013 | 03:55 PM
Bix VT's Avatar
I would use manifold vacuum for the bov.
Edit: you may find this thread handy: https://honda-tech.com/forums/forced-induction-16/wastegate-blow-off-valve-hookup-howto-3005324/
Old Jan 2, 2013 | 04:48 PM
Vagitarian's Avatar
Alright, Ill have to get some sort of adapter as the intake manifold barb is 3/8" while the bov is quite a bit smaller
Old Jan 2, 2013 | 05:22 PM
KevinEF7's Avatar
Is the compressor housing even a good spot to get a source from?
Old Jan 2, 2013 | 06:41 PM
turbociv910's Avatar
bov requires vacuum, I opt for the largest nipple/source.
i like to run the nipple off the turbo for the wastegate, usually cleans up a line running across the engine bay.
Old Jan 2, 2013 | 06:47 PM
wantboost's Avatar
Who is Mr Robot?
You have to run a source after the throttle body for the blow off valve... or it won't work
Compressor housing will work for the wastegate but if you're running off the spring you'll see lower pressure at the intake manifold due to pressure drop
dadrought6
Nov 11, 2009 06:22 AM
iNERtIA
Mar 22, 2007 03:24 PM
niedejb
Jun 7, 2002 06:26 PM
Smoothy
Nov 14, 2001 08:48 PM
GruvyTune
Oct 22, 2001 06:16 PM
