Honda CR-V & Element 2WD & 4WD Element & CR-V
Stumbling acceleration after warm up
Old Jan 2, 2013 | 05:27 AM
curtdantom's Avatar
Default Stumbling acceleration after warm up
I have a 2000 CRV 260k miles. Recently it developed an acceleration problem after it warms up. Runs great cold, no miss, 1500rpm,smooth idle,fast accel. Normal. As soon as it warms up it drops to 300 400 rpm. Stumbles through acceleration and lacks power big time. Checked for vacum leaks, changed fuel filter, fuel pump, checked plugs, (new distributer, plugs, wire 3k ago. With advice and instruction from this sight I cleaned the IACV and the FITV and adjusted the idle to specs. Results were even smoother when cold, same problem when warm. Last error code read P0132 Primary heated O2 sensor circut highvoltage (Sensor 1). Changed O2 sensors about 15k ago. Should I change both again? Not cheap as you know. First time posting on one of these hope doing it right. Thanks
Old Feb 17, 2013 | 06:13 PM
bcp7272's Avatar
Default Re: Stumbling acceleration after warm up
I had a 98 that did the same thing. Sold it to a mechanic, he seems to think it a bad ecu.
9thgenidiot
Jun 24, 2015 01:12 PM
Magik123
Jun 13, 2007 05:10 PM
raylude
May 24, 2005 08:04 AM
awdriscol4
Apr 26, 2005 02:45 PM
prelude2005
Oct 30, 2004 08:03 AM
