Stage 4 Racing clutch adjustment...
Hello all, I'm a pretty good noob to the forum, along with the Honda Community, with just recently buying a 94 Honda Civic ex, that had been converted from an auto to a manual, with a 1994 Inegra motor and trans, along with a stage 4 racing clutch. I've done a lot of reading here, and still could not find how to adjust the clutch arm, to adjust the engagement of the clutch.
Right now you barely have to press the clutch to change gears. I want to be able to press the clutch down some to change gears. Being a racing style clutch, is that even possible??? If so, how?
Thank you.
Thank you.
First off, "stage 4" means nothing. Second off, moving the engagement position won't give you more feathering range, if that's what you're going for.
If you still want to try to adjust it, there's a nut on the top of the clutch pedal attached to the hydraulic shaft. You can adjust the pedal height there.
I've messed with both nuts on the shaft, and still no difference. I wasn't sure if there were any other places that there could be an adjustment made, or what?
