Does any one know how to make the str drag maxx intake manifold work correctly on 99 honda civic si?
O.k. im having difficulty im running a set of civic type r cams with STR adjustible cam gears both are retarded 2 degrees and I just installed a STR drag manifold that I had sitting around that belonged to my B16a first gen.Now Im having problems, first of all I had to use a OBD zero air charge sensor but the car runs fine till about 4500RPM then it seems like it runs like its cold and at full throttle my check engine light comes on and the code reads oxygen sensor. Does anybody have any ideas about what i can do?
An OBD Zero Air Charge Sensor is a sensor off the first generation of the B16A. OBD Zero is first generation, OBD One is second and third generation, and OBD two is fourth generation ---> "TYPE R" "SI" "GSR"
CRVTECSCREAMER
Mar 19, 2010 04:00 AM
Emoson
Aug 10, 2004 05:35 PM
