Mini Me Swap won't start!!
Old Jan 1, 2013 | 06:59 PM
92vtecZChatch's Avatar
Default Mini Me Swap won't start!!
I just got done doing a mini me swap on my buddies 95 civic. Its a ZC block with a Z6 head. I have fuel, spark and its timed correctly. But for some reason the starter just keeps spinning and motor won't turn over. I think the valves might not be closing but I don't want to tear it back apart yet until I hear what others have to say.
Old Jan 2, 2013 | 02:11 PM
Default Re: Mini Me Swap won't start!!
Anyone have any ideas?
Old Jan 2, 2013 | 02:13 PM
nub's Avatar
nub
Check and set valve lash if needed
Re check mechanical timing
Double check firing order
Old Jan 2, 2013 | 04:06 PM
fcm's Avatar
fcm
Old Fart
You need fuel spark and compression, if you think compression is a problem, "I think the valves might not be closing" do a compression test.
Also your post is confusing, you said, "the starter just keeps spinning and motor won't turn over" please clarify.
Your statement indicates the starter motor is working, "starter just keeps spinning" but you say, "motor won't turn over", that sounds like the starter motor is not engaging, not cranking the engine, cranking and turning over are the same thing.
Or did you mean starter works, engine cranks, [turns over] but will not "fire", [start]?
I am assuming you mean the latter, engine cranks but will not start. 94
Old Jan 2, 2013 | 06:58 PM
Sorry for the confusion. The engine cranks but it won't fire!
Also how do I check and set the valve lash?
Old Jan 3, 2013 | 11:18 AM
nub's Avatar
nub
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/tech-article-valve-lash-adjustment-1305086/
I'd double check the mechanical timing before setting the lash personally.
How did you set the cam? Level with head or at 7 o clock?
Old Jan 3, 2013 | 11:34 AM
fcm's Avatar
fcm
Old Fart
A compression test will tell you if it is a possible valve issue, valve lash "too tight".
If there is no compression pull the VC and adjust the valve lash, if lash is good do a leak down test to see where the leak is, if on the other hand compression is good, recheck both valve and ign. timing. 94
Old Jan 4, 2013 | 06:04 AM
Eg.ls.turbo's Avatar
Did u check if ur distributor is timed? Spark plugs backwards?
Old Jan 4, 2013 | 06:33 PM
What do you mean spark plugs backwards? You meaning incorrect firing order? And the distributor won't go in if its but one way?
Old Jan 4, 2013 | 06:41 PM
I can't find the the link I used. But it said to set the cam and crank at TDC, then loosen the timing belt tensioner, now rotate the crank 5-6 times clockwise this will set the time, now rotate the crank pulley counterclockwise 3 times, finally tighten the tensioner and it will be set. I found the same thing in a few different threads but it still didn't work!
Old Jan 4, 2013 | 06:42 PM
My buddy said since its a ZC I need to take the ZC cam gear off the stock head and put it on the Z6 head. But I don't see how that would fix anything?
Old Jan 4, 2013 | 07:15 PM
Hondaguy83's Avatar
Compression/ignition timing/spray stArter fluid in and see if it starts.
Old Jan 5, 2013 | 04:31 AM
Yea make sure plug wires in correct firing order. And distributor goes in one way but the coil inside the distributor needs to pointed to number 1 plug wire. So set piston 1 at tdc and make sure cams are tdc and set ur distributor to number plug wire plug, unscrew distributor cap and check. If its not pointed to the correct tdc firing order then unbolt it and simply turn it by hand. Hope that helps
Let me if that was it
Old Jan 5, 2013 | 04:40 AM
Didnt know u could turn a import motor clockwise only counter clockwise, thought that would cause the piston and valve to hit each other if turnin crank clockwise
Old Jan 5, 2013 | 08:44 AM
nub's Avatar
nub
If that's how you actually did it you're doing it wrong. The engine rotates counter clockwise. Nowhere in the process do you rotate the engine clockwise to set the timing. Download a FSM for a 92-95 Civic and follow the proceedure for setting mechanical timing for a Z6
Don't listen to your buddy.
Old Jan 5, 2013 | 09:54 AM
A helms manual is like $20-$25 dollars at ur local parts store a lil pricey for a book but well worth it in the end. Get one and it'll tell everything on timing and other stuff... Etc
Old Jan 5, 2013 | 11:58 AM
h22speed's Avatar
Old Jan 5, 2013 | 01:27 PM
nub's Avatar
nub
There are FREE downloads of the FSM on the web.
Old Jan 5, 2013 | 06:42 PM
Guess I'm not following you on the FSM?
Old Jan 6, 2013 | 10:50 AM
nub's Avatar
nub
Factory Service Manual
95delsolz6
Dec 10, 2009 03:33 PM
Slacker87
Nov 9, 2006 11:09 AM
Chief Brody
Honda Motorcycles
22
Jul 30, 2004 04:00 PM
00fbp
Jul 28, 2003 07:06 PM
