shoulder belt won't move when its cold outside!?
i'd say when its about 30 or less outside the shoulder strap doesn't retract. not that its a big deal, it just chokes me when i get out from starting it up and it doesn't move!
any ideas to get it to move first thing?
Unfortunately, the FSM only illustrates removing and re-installing seat belt retractor. It also recommends replacing if there is a problem. You could try squirt of PBlaster or WD40.
Are you aware of how to wind a seat belt? Its pretty much the same as winding a tape measure only you have gyro technology in play as well. Mine were the same in my accord so i put a few extra winds on them because over time metal especially in springs, relaxes which is why garage door springs break. Grease or oil on something as sensitive as a gyro operated seat belt assy is against my religion. Reason is because grease and oils not only hold dirt but attract it. Especially wd40.
Posted from Honda-tech.com App for Android
soooooooo you're saying not to put wd40 on it
