Jumpy Tach when signals on
Old Dec 31, 2012 | 07:03 PM
CrxGrin's Avatar
Default Jumpy Tach when signals on
I just finished replacing my engine/body/dash harness. The car runs fine but when I put my turn signals on the tac jumps everywere, and when I hit my brights the tach goes to zero and stays there. Checked all the grounds I could find and nothing was loose/corroded. Not sure if it's connected but my apline head unit wont work either. Any ideas?
Old Jan 1, 2013 | 06:13 AM
CrxGrin's Avatar
Default Re: Jumpy Tach when signals on
Temp gauge isn't working either.
Old Jan 1, 2013 | 08:25 AM
juba_x's Avatar
When mine did that i pulled the cluster and tightened the power and ground one the back of it
Old Jan 1, 2013 | 09:49 AM
KINGVEM^^ED6's Avatar
Check all your grounds
When mine did this the battery cable ground was loose
Old Jan 1, 2013 | 04:39 PM
CrxGrin's Avatar
Yea i checked all my grounds, couldnt find anything wrong. I'll sand all of them down and see if that works.
Old Jan 1, 2013 | 06:03 PM
CrxGrin's Avatar
I didn't even see a power and ground cable on my cluster lol.... All i have it the 3 harness plugs in it.
Old Jan 1, 2013 | 06:12 PM
CrxGrin's Avatar
I have 2 grounds under the dash via the harness, ground from trans to body,motor to body. my batt is relocated and grounded to the spare tire bolt.
Old Jan 2, 2013 | 04:47 AM
CrxGrin's Avatar
Was a bad alternator, threw a new one on this morning and everything works fine!
kenmar
May 24, 2013 01:23 AM
98bucket
Aug 3, 2011 07:58 PM
FernEF
Jun 22, 2007 04:26 PM
mugenhatch92
Mar 30, 2006 12:26 PM
Ivan
Aug 13, 2003 06:33 PM
