Will I reach my goal??gsr turbo build
Old Dec 31, 2012 | 06:28 PM
milanoitr's Avatar
Default Will I reach my goal??gsr turbo build
Hello h-t I'm about to start my build and just wanted to get some input from some bellow h-t members...here's what I'm planning on doing any advice is appreciated...am i forgetting anything??looking to get 700+hp...what do you think???
Block:
Eagle sleeved to 84.5
9:1 cr pistons not sure what brand to use
Eagle rods,might switch to Manley Tt rods if money isn't tight
Head:
Blox stg 1 cams
Super tech valve springs and retainers
Skunk 2 intake manifold
Cosmetic head gasket
Turbo:
Full race dual waste gate manifold top mount
Gt35r
Tial 38mm waste gates
Greddy bov
3" down pipe
3" inercooler piping
Fuel setup:
Full blown in tank dual pumps
1000cc injectors????
110 octane or c16????
Tranny:
Gsr
LSD
Clutch master twin disk
Old Dec 31, 2012 | 08:25 PM
milanoitr's Avatar
Default Re: Will I reach my goal??gsr turbo build
Anyone??
Old Dec 31, 2012 | 09:51 PM
wantboost's Avatar
Who is Mr Robot?
Won't make 700 with a gt35
Old Dec 31, 2012 | 11:28 PM
duf2570's Avatar
For the fuel go for what you can get...
Old Jan 1, 2013 | 01:51 AM
th3pwn3r's Avatar
I see lots of people with 40Rs making that kind of power. However, a 35R would come close.
Old Jan 1, 2013 | 10:20 AM
TheShodan's Avatar
Moderator
Old Jan 1, 2013 | 11:04 AM
kennybuilt teg's Avatar
that setup will put you in the 600-650hp range and that should be more then enough. deff run c16 though. easy to find and consistent 117 Oct fuel.
Posted from Honda-tech.com App for Android
Old Jan 1, 2013 | 12:03 PM
milanoitr's Avatar
Ok thanks for the info what injectors should I go with
Old Jan 1, 2013 | 12:10 PM
1600cc
Old Jan 1, 2013 | 12:16 PM
nice build btw. its a good start are you on 82 ar exhaust housing?
Old Jan 1, 2013 | 03:12 PM
milanoitr's Avatar
Not sure haven't gotten the turbo yet I'm pretty sure tho....are 1600cc overkill???
Old Jan 1, 2013 | 03:43 PM
what would I know? I run 8x 2000cc. buy em once and done. I'd rather have to much injector then not enough. at that hp injector duty cycle would be at 60-70 vs the 80-100 you'll be running on the 1000cc
Old Jan 1, 2013 | 03:59 PM
milanoitr's Avatar
Yea I didn't think of it that way lol...thanks for all the input...can't wait to get this thing up and going dropping it in a Ef hatch hopefully I can hit low 11's that would be nice haha
Old Jan 1, 2013 | 04:11 PM
look up the old dsport black eg. it had same setup daily driven and went 10.0! look it up and follow what they did. and np if I can help with any info I have I'm always willing to give it.
Old Jan 1, 2013 | 04:17 PM
milanoitr's Avatar
I'll look it up right now thanks for the help...this is my first high hp build so I'll need ll the help I can get
Old Jan 2, 2013 | 01:55 AM
Justins00ss's Avatar
Looks like a fun build
Old Jan 2, 2013 | 11:06 AM
milanoitr's Avatar
Yea fun and expensive but well worth it in the end
Old Jan 2, 2013 | 04:22 PM
drewr4411's Avatar
You will not hit 700hp with a 35R and 1000cc injectors. This isnt a honda, but my DSM build I had 1200cc JMF SMIM, PTE6262 .82ar 3" Piping and exhaust, q45 TB and full -8an feed and OEM return system, FP4 stroker cams, and more.. I only made 508hp on 93 octane @26psi using a Dyno Dynamics dyno.
Also, again not a honda but I have never had good luck with anything comectic. OEM or 5 layer MLS is what i have used in the past to hold 30+psi.
Drew
Old Jan 3, 2013 | 05:27 PM
milanoitr's Avatar
What do you guys think of a Borg Warner twin scroll t88 to big???dknt know exact specs of it right now will no in a hr or so...guy said its capable of 1000hp...what do you guys think anyone have any experience with this turbo
Old Jan 3, 2013 | 06:35 PM
milanoitr's Avatar
Anybody
Old Jan 3, 2013 | 07:15 PM
TheShodan's Avatar
Moderator
You'll Never move this turbo with anything smaller than 3.0-7.0 litres. And even then they would be over 30-60psi of boost pressure. For a measly 700 comparatively, you would never enjoy or utilize this turbo for any reason.
Old Jan 3, 2013 | 08:50 PM
milanoitr's Avatar
I've seen them on Hondas before
Old Jan 3, 2013 | 09:01 PM
torkh22a's Avatar
700hp in an ef? i sure hope you go under 11s.
Old Jan 4, 2013 | 06:39 PM
milanoitr's Avatar
The turbo is a s400 sx 110 a/r exhaust
Old Jan 4, 2013 | 06:45 PM
TheShodan's Avatar
Moderator
That's great. where ever it was you saw them was an idiot for trying to run it as some sort of street car. For a full track application, different story. My grandmother's 50 trim could catch a car with that large of a turbo from half a mile back and still win before it could utilize it.
