d16z6 tps help
Old Dec 31, 2012 | 02:50 PM
woahdelsol's Avatar
Icon3 d16z6 tps help
okay so i swapped my rebuilt motor from my si into my new S chassis. no problems with engine before swap. when i swapped new engine in, it had a poor idle and would surge. and CEL codes, 2- vtec solenoid, 3-MAP, 6-water temp, 7-TPS, 14-IAC. so i went ahead and cleaned my throttle body, iacv and fitv. after doing so, the problem did not seem to be fixed. i purchased a map and TPS sensor off of craigslist which said to be in working condition. i went ahead and replaced both sensors.
now i know that the tps must be adjusted. i do not know exactly how to do so, but i used this guide for help, https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/official-honda-tps-wiring-calibration-thread-2830131/
when checking red wire i get no reading when the throttle body is closed, and i get about .3 when open. i do not have a continunity tester at this time to check for ground.
yellow wire reads 5v
im not sure what to do from this point, any and all help would be great!
thanks in advance.
Old Dec 31, 2012 | 02:52 PM
woahdelsol's Avatar
Default Re: d16z6 tps help
also when i try to move/adjust the sensor position itself, the reading does not change. could be bad TPS sensor? i should probably check my old one for the hell of it.
Old Dec 31, 2012 | 05:02 PM
hybridmiklo's Avatar
continuity tester? Are you using a dmm? If you get 5reference, and you get an unusual reading going back to the ecu, then there is a bad ground. Do a voltage drop on the ground side
Old Dec 31, 2012 | 05:43 PM
woahdelsol's Avatar
i will try this tomorrow and see what happens. thanks for the help.
video_voide
Nov 22, 2015 11:21 AM
Pimpdarvis
Sep 11, 2013 05:24 PM
jake1191
Engine Management and Tuning
Jul 18, 2011 06:42 AM
si90rex
Mar 30, 2006 12:54 PM
JDMSirEK4
Aug 26, 2005 05:48 AM
