hondata s200 box not connecting
Old Dec 31, 2012 | 09:24 AM
waynebennett77's Avatar
Default hondata s200 box not connecting
My p72 ecu wont connect to the hondata s200 box. The led is flashing slowly. Ive checked the ecu and everything seems to be ok. The ecu has been configered before and is working great. But i just got a turbo installed and trying to reconfiger for the 3 bar map sensor.
Any help would be great
Old Jan 2, 2013 | 12:57 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: hondata s200 box not connecting
Sorry to burst your tuning bubble, but RomEditor4 has been discontinued, there is no way you will be able to modify or tune with the S200.
Some tuners are still authorized with a special version of RE4, you can contact them, but frankly it's not worth it.
Crome is the equivalent of S200, or you can upgrade to a Neptune/Demon package without having to modify the ECU.
Old Jan 2, 2013 | 01:40 PM
Spunkster's Avatar
What program are you using to modify the chip?
Old Jan 6, 2013 | 08:29 AM
Ya discontinued :-( my money is a little limited and im in a country where stuff like this is hard to find, that why i bought the used s200 in the first place. I found some guy called DIY mike on ebay does custom ecu's tuned to your specific config and its in my price range, but it seems to be too good to be true, can anyone advise me about this. Heres a link to his product http://www.ebay.com/itm/180898831575...=p5197.c0.m619
Old Jan 6, 2013 | 08:37 AM
diesel718's Avatar
http://www.xenocron.com/
^^^^^GIVE THESE GUYS A CALL^^^^^^
Old Jan 6, 2013 | 08:56 AM
Thanx diesel718, but i still need to have it tuned localy for the map sensor, and my problem is that there is no one in my country to tune it for me. If it came with a box like a s200 or s300 then i could tune myself but then again if my s200 box was working i wouldnt have this problem in the first place my solution is to order an ecu with an s300 from hondata but i just cant aford that kinda money. I know looking for the cheap way out always gets you more trouble then you started with but when you aint got it..........
Old Jan 7, 2013 | 02:40 PM
Spunkster's Avatar
The s200 will not work with an ebay calibration. It can only be tuned by someone with Romeditor.
Old Jan 23, 2013 | 04:42 PM
I'm Huge In Japan
You need a chip burner or emulator from Xenocron to use with Crome or Neptune, and a wideband O2 controller to tune it yourself. Nothing you buy on eBay will be programmed correctly for your engine, and will most likely destroy your investment. You can download the manual in my sig to get you started.
Old Jan 30, 2013 | 07:37 AM
Thanx VegasInvasion, ill read throw the manual. Im thinking a chip burner and reburning my chip with crome is the best way to go
Old Feb 16, 2013 | 09:52 AM
I'm Huge In Japan
not really the "best" way to go, but a relatively linear alternative. The best way to go is a Demon with Neptune. It should fit right into the existing S200 socket.
waynebennett77
Dec 31, 2012 09:34 AM
HondaHead211
Apr 11, 2006 03:00 PM
MrPink69
Jul 19, 2005 12:17 PM
95turbogsr
Jun 26, 2005 09:17 AM
