Honda CR-V & Element 2WD & 4WD Element & CR-V
Rear disk brakes on a awd crv?
Old Dec 31, 2012 | 07:16 AM
BriantheButcher's Avatar
Default Rear disk brakes on a awd crv?
My buddy had a 98 awd and wants to put disk brakes on the rear. Is there a setup that will work? Any stock crv's with rear disks? A combo of parts that will work? Any help is appreciated.
Old Dec 31, 2012 | 08:23 AM
LDForget's Avatar
Default Re: Rear disk brakes on a awd crv?
no. Only a custom setup will work.
Old Jan 1, 2013 | 07:17 AM
94EG8's Avatar
Seagull Management
ITR rear calipers and rotors with custom mounting brackets are going to be the closest thing you're going to find to a bolt on conversion.
Old Jan 1, 2013 | 07:29 AM
fitseries3's Avatar
any rear calipers will work since you have to make a bracket for them. prelude or rsx rear rotors have same hole pattern as crv
i got a set off a 97-01 prelude at the local junk yard for cheap. be sure to get the ebrake cables as well though.
Old Jan 1, 2013 | 10:38 AM
94EG8's Avatar
Seagull Management
I mentioned ITR since the CR-V front calipers are the same as ITR, using ITR rear calipers wont throw off your brake bias.
The biggest problem you're going to run into is:
A. Finding ITR calipers for a reasonable price (EP3 are basically the same IIRC but the bleeder will be upside down so they need to be bleed unbolted from the trailing arm)
B. Parking brake cables. I'm not sure if Civic or Integra parking brake cables will fit.
Old Jan 1, 2013 | 10:54 AM
fitseries3's Avatar
prelude ebrake cables work, hence why i mentioned them. the caliper itself isnt the only thing that will change the bias, the rotor can too. a bigger rotor will shift more bias to the rear when using the same caliper.
you can even use odyssey/pilot rear rotors which are pretty good size and are 5 lug.
Old Jan 2, 2013 | 06:21 PM
dc2low's Avatar
Im interested in doing this swap on my crv also.
Old Jan 3, 2013 | 02:47 AM
qwrty's Avatar
prelude rear disc worked before but as said, fabricated brackets for the caliper.....
** any rear disc set will work, but its up for you how to mount and make the brackets for
the caliper, we tackled around this issue a year ago but i never got a chance to fully work
on to it... to much time for me alone to tackle coz i dont have my fabricator around...
now im looking into the 2nd gen crv's rear disc kit since theres a lot on the salvage yard and
sourcing out for parts wont be that hard... good luck on those who'll try to make thism keep us posted!!!
Old Feb 6, 2013 | 05:09 PM
canario86's Avatar
wow thats nice info rigth .................
Old Feb 13, 2013 | 07:32 PM
jdm_bones's Avatar
Someone should fabricate a kit and sell it on the market.
Old Feb 13, 2013 | 07:53 PM
Dc2_ShowStopper's Avatar
X2
gldndrgn14
May 10, 2006 02:02 PM
Rash Ej1 SiR
Apr 5, 2006 09:13 PM
Dom_GsR
Aug 10, 2004 07:34 PM
QWKPHKR
Feb 21, 2003 09:47 PM
2fcknfst
Oct 8, 2001 06:02 PM
