FT kicker 1Ch. amp zx400.1 for some 6X9s
looking to trade this amp for some good 6x9s. LMK what you got. 323.979.4253 Mike [Clackamas.]
Height: 2-1/8", 54mmWidth: 9-5/8", 244mm
Active Crossover: 24dB/octave, variable 50Hz-200Hz, low pass only
High-Efficiency Class-D Design in most monoblock amps
Frequency Response: 25-200Hz, +0/-1dB
Input Sensitivity: High Level 250mV-10V, Low Level 125mV-5V
Signal-to-Noise Ratio: >95dB, a-weighted, re: rated power
24dB/octave high-pass subsonic filter fixed @ 25Hz
KICKEQ™ Boost: Variable to +18dB ,centered @ 40Hz
