cooling system issues
Old Dec 30, 2012 | 02:07 PM
Billy Baird's Avatar
Default cooling system issues
hey i just replaced the thermostat, fan sensor, temp-gauge sensor, radiator and the res, my car has been flushed and filled bleed and all that good stuff but its still not going thru the system and keeps blowing out of the res and the thermostat is installed correctly im lost here the only things i have left i can replace on the cooling system is the headgasket and waterpump i need an answer or ideas
Old Dec 30, 2012 | 02:21 PM
Wdpfreak145's Avatar
Default Re: cooling system issues
I notice you're a new member to honda-tech. Here are a few starters so that you can better help us to help you.
ALWAYS give relevant information.
Year and make of your car
engine (if you think it will help)
any maintenance you've done regarding the issue
any upgrades done to the part of the car you're having trouble with
And ALWAYS use the search function to make sure someone hasn't had the same issue as you and found a solution in a thread they created. A lot of times your questions will be answered in older threads.
So is the car overheating? Is the lower radiator hose hot or cold? Does it have pressure when you squeeze it?
Old Dec 30, 2012 | 03:15 PM
its a 98 civic dx coupe and d16y7 motor and if i have the heat on it has no pressure and if its off and i start driving for a few mins it builds up pressure but the bottom hose never gets warm and i dont think its over heating the coolant that sprays out of the res isnt too hot either. its only gets pressure if i have been driving, so i clueless on this issue
voxleo
Jul 22, 2012 04:50 PM
cjwarren4dacord
Nov 27, 2010 04:13 AM
rktechteg
Dec 29, 2008 05:17 AM
supermotothud
Dec 19, 2008 01:38 AM
killeri
Jun 15, 2003 01:35 PM
