fuel pump not priming/no power to starter
Old Dec 30, 2012 | 12:21 PM
f90w's Avatar
Default fuel pump not priming/no power to starter
I have a 96 civic ex that was swapped with a b16a2. The car ran fine and I let sit a few days during Christmas then today I went to go start it and the fuel pump is not priming, and the starter does not have power. We've already swapped ecu's, replaced main relay, and checked fuses. Any ideas on anything else i can check to make it not do anything?
Old Dec 30, 2012 | 12:22 PM
grumblemarc's Avatar
The Grumpiest
Default Re: fuel pump not priming/no power to starter
Grounds. Check them. Specifically the thermostat ground.
Old Dec 30, 2012 | 02:20 PM
f90w's Avatar
thanks it was a ground on the transmission that we didnt see
Old Dec 30, 2012 | 02:21 PM
The Grumpiest
Excellent. I keep forgetting about that one.
Old Dec 30, 2012 | 02:35 PM
diesel718's Avatar
i just went threw this the other day...check ground connections, and then check to see if you have power to the starter when the key is in the start position, if not then you have a ignition switch problem..my problem was that there was a small 2 wire black box that get screwed to the ignition switch and it came off..when i re connected it, my car started...but my car is a DA
Old Dec 30, 2012 | 02:46 PM
The Grumpiest
He fixed it.
Old Dec 30, 2012 | 04:26 PM
diesel718's Avatar
Originally Posted by grumblemarc
He fixed it.
oh lol...all i read was his problem sorry lol
EKnewit
Jun 10, 2018 09:12 AM
acura94imported
Apr 19, 2014 09:15 AM
VtecLsEater
Jul 7, 2009 08:14 AM
tannerLSt
Jan 19, 2008 07:34 PM
Xumarius
Nov 1, 2004 08:07 AM
