need ideas.... car not starting
Subscribe
Jan 16, 2008 | 04:08 PM
here is the deal.... car was boosted before.... everything worked fine...
pulled the motor to build it... its in. ready to go, relocated the battery to front floor board.
starter doesn't turn over when i turn the key, starter turns when i jump it via starter power to starter signal....
checked all the fuses, jumped the clutch switch
any ideas?
Reply 0
Jan 16, 2008 | 04:37 PM
no ideas anyone?
Reply 0
Jan 16, 2008 | 05:24 PM
Re: (tannerLSt)
does the fuel pump prime when you turn the ignition on?
Reply 0
Jan 16, 2008 | 05:48 PM
Re: (trav95civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trav95civic &raquo;</TD></TR><TR><TD CLASS="quote">does the fuel pump prime when you turn the ignition on?</TD></TR></TABLE>
fuel pump primes, cluster lights come on(no dimming)
when i try to start the lights on the a/c controls go out
Reply 0
Jan 16, 2008 | 05:50 PM
Re: (tannerLSt)
check all ground connections on the motor, sounds like to me there is some kind of back feed problem in the electrical.
Reply 0
Jan 16, 2008 | 06:04 PM
i've check the grounds.... i guess i'll check them again tomorrow but they are all tight
Reply 0
Jan 16, 2008 | 06:09 PM
Re: (tannerLSt)
if you are sure all ground connections are good then your best bed would to get a voltmeter, make sure that you have power coming from the ignition to the starter selenoid. If you got a helms manual for your car it will be your bible when dealing with electrical connections. Your loosing power somewhere, could be something simple as a bad connection in a plug or even just a split wire
Reply 0
Jan 16, 2008 | 06:14 PM
Re: (trav95civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trav95civic &raquo;</TD></TR><TR><TD CLASS="quote">if you are sure all ground connections are good then your best bed would to get a voltmeter, make sure that you have power coming from the ignition to the starter selenoid. If you got a helms manual for your car it will be your bible when dealing with electrical connections. Your loosing power somewhere, could be something simple as a bad connection in a plug or even just a split wire</TD></TR></TABLE>
well i'm guessing it MIGHT be a bad connection, cause everything worked fine before, i pulled the motor out 6-7 months ago , and the car has been sitting ever since... only thing i did different was relocate the battery to fit my catchcan
Reply 0
Jan 16, 2008 | 06:25 PM
Re: (tannerLSt)
ive had wiring problems myself on my eg. IMO there the worst thing to figure out on a car just b/c the problem can be near impossible to find without the manual or a meter. then you can feel completely stupid when you find wat the issue was haha. But gl with finding the problem man
Reply 0
Jan 16, 2008 | 06:29 PM
Re: (trav95civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trav95civic &raquo;</TD></TR><TR><TD CLASS="quote">ive had wiring problems myself on my eg. IMO there the worst thing to figure out on a car just b/c the problem can be near impossible to find without the manual or a meter. then you can feel completely stupid when you find wat the issue was haha. But gl with finding the problem man </TD></TR></TABLE>
ya i'm not all about finding some electrical problems... its gonna suck...
thinking about just jumping the starter to start the car when i drive it... LOL j/k
might just end up paying someone to find out whats wrong!!!!!
Reply 0
Jan 17, 2008 | 02:41 AM
Re: (tannerLSt)
Well, it doesn't make sense that the ignition switch would be the issue. If the fuel pump is priming, then power is getting to the main fuse under the hood, as well as to the main relay. This is all first in line, in terms of power distribution, so your positive side of the battery is mostlikely alright. Problems like this are almost always ground wires.
Track your ground wire and power back from the starter itself and be sure both are good. This is very likely a simple issue, you just need to find it.
Reply 0
Jan 17, 2008 | 02:57 AM
Re: (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Well, it doesn't make sense that the ignition switch would be the issue. If the fuel pump is priming, then power is getting to the main fuse under the hood, as well as to the main relay. This is all first in line, in terms of power distribution, so your positive side of the battery is mostlikely alright. Problems like this are almost always ground wires.
Track your ground wire and power back from the starter itself and be sure both are good. This is very likely a simple issue, you just need to find it.</TD></TR></TABLE>
a simple issue that i don't feel like messing with... lol
hopefully i can get my buddy with a multimeter over here this weekend and try and track it down... i hate electrical ****! if i can't find the problems i'm just gonna take it to tony and have him find it!
that would be nice if it was just a ground
Reply 0
Jan 17, 2008 | 05:50 AM
Re: (tannerLSt)
If it was a ground i don't think it would start when you manually send 12v to the solenoid.
Reply 0
Jan 17, 2008 | 06:40 AM
Re: (tony1)
jeff's car randomly wouldnt start on the dyno in the middle of a tuning session, turned out the ignition switch simply just took a crap. it would start just fine when manually jumping the starter.
i also had a very similar problem on a supra, turned out a plug on the fuse box was unplugged by doubtful thats the problem on a honda.
will the car START when you jump the starter or just turn over?
Reply 0
Jan 17, 2008 | 01:23 PM
Re: (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">jeff's car randomly wouldnt start on the dyno in the middle of a tuning session, turned out the ignition switch simply just took a crap. it would start just fine when manually jumping the starter.
will the car START when you jump the starter or just turn over?</TD></TR></TABLE>
i haven't actually tried to start it, i was just making sure everything was working right, and i need to get some good gas in there, the car has been sitting for 6-7 months so i need to take that crap out and put some new gas in... i tried cranking it over with the spark plug wires out....
but it was having problems with the ignition before, when i got wheel hop or hit a big bump it would turn the car off, the key was turning back and shutting off the car... i swapped the ignition(only the part you put your key in) and it helped some, but if i remember right it still turned off every once and a while...
Reply 0
Jan 18, 2008 | 03:06 AM
getting a multimeter over here saturday... any more ideas before then?
Reply 0
Jan 19, 2008 | 08:47 AM
Re: (Turbo-charged)
ok i threw the spark plugs in.... and NO ITS NOT STARTING.... no spark
Reply 0
Jan 19, 2008 | 02:25 PM
fixed my starter problem.... it was the ignition.... but i'm still not getting spark. gotta get a new dizzy and see if thats my problem
Reply 0
Jan 19, 2008 | 07:34 PM
got it running
thanks for the replys
Reply 0
Subscribe
