350whp 250trq Ls/V Turbo High Comp!
Finally got around to getting my car tuned
Chassis: 1995 EX Coupe-full interior street machine. Everybody meet Victoria!
Engine:
Stock B18 Block
Stock rods & bolts. UPDATE: CAR HAS ARP ROD BOLTS AS OF 2/25/2013
Nippon Racing pr3 (b16 ) pistons *81mm* 11.5.1-11.8.1 compression
Golden eagle ls vtec kit
oem head gasket
b16 im & tb
Stock b16 head
ls transmission
f1 stg 3 6-puck clutch (gripforce)
koyo radiator
Turbo Setup:
Garrett 60-1 journal bearing .63
Go-autoworks Intercooler piping kit
Go-Autoworks Cast manifold V2
Speedfactory 4bar map sensor
Cx racing intercooler
Cx racing turbo blanket
godspeed wastegate
3" downpipe & exhaust
hks bov
Black hallman manual boost controller
Fuel Setup:
RC 750 cc high impedance injectors
aem fuel pressure regulator
blox fuel pressure gauge
hayame fuel rail
6-an fuel line
walbro 255
Pump e85
13PSI
PICTURE UPDATES ON PAGE 2&3 *1-13-2013*
305whp @ 10psi, final pull @ 13psi yielding 346whp and 249trq
SORRY FOR THE BIG *** PICTURES
Engine:
Stock B18 Block
oem head gasket
b16 im & tb
Stock b16 head
ls transmission
koyo radiator
Turbo Setup:
godspeed wastegate
hks bov
Fuel Setup:
hayame fuel rail
6-an fuel line
walbro 255
Pump e85
13PSI
I'm using a Garrett "57 trim", stage V turbine wheel, v-band adapter to downpipe, Tial 44mm wastegate (v-band) routed into the exhaust, Tial 50mm Blow off valve, Precision 600hp intercooler, aluminum 2.5" charge piping, 3" stainless exhaust piping to cutout.
Here's a pic. Sorry for the thread jack.
305 pull was on 10 psi with no timing according to my tuner. after that adjustments to boost controller (upped the boost) were made timing was added accoringly etc. As far as wrap that is dei titanium exhaust wrap.
