350whp 250trq Ls/V Turbo High Comp!
Finally got around to getting my car tuned
Chassis: 1995 EX Coupe-full interior street machine. Everybody meet Victoria! Engine: Stock B18 Block Stock rods & bolts. UPDATE: CAR HAS ARP ROD BOLTS AS OF 2/25/2013 Nippon Racing pr3 (b16 ) pistons *81mm* 11.5.1-11.8.1 compression Golden eagle ls vtec kit oem head gasket b16 im & tb Stock b16 head ls transmission f1 stg 3 6-puck clutch (gripforce) koyo radiator Turbo Setup: Garrett 60-1 journal bearing .63 Go-autoworks Intercooler piping kit Go-Autoworks Cast manifold V2 Speedfactory 4bar map sensor Cx racing intercooler Cx racing turbo blanket godspeed wastegate 3" downpipe & exhaust hks bov Black hallman manual boost controller Fuel Setup: RC 750 cc high impedance injectors aem fuel pressure regulator blox fuel pressure gauge hayame fuel rail 6-an fuel line walbro 255 Pump e85 13PSI PICTURE UPDATES ON PAGE 2&3 *1-13-2013* 305whp @ 10psi, final pull @ 13psi yielding 346whp and 249trq SORRY FOR THE BIG ASS PICTURES :) http://i650.photobucket.com/albums/u...A483F95B83.jpg http://i650.photobucket.com/albums/u...2DA09B2418.jpg http://i650.photobucket.com/albums/u...2D2ABA3026.jpg http://i650.photobucket.com/albums/u...2E3D57781D.jpg http://i650.photobucket.com/albums/u...2E479A1F68.jpg |
Re: 350whp 250trq Ls/V Turbo High Comp!
:thumbup:
Nice build and car.
You put some cams in there, and on my lord.
nice number..full boost at??whyyy oh why we dont have e85 here!!
Originally Posted by ALL M0T0R
(Post 48275139)
How many psi??
It says in his first post... 13
Originally Posted by wantboost
(Post 48277307)
simple & clean setup pal.
Good job. |
Thanks Charlie =)
Nice!
I'm using a similar turbo making about he same numbers. |
Nice! Thats getting it done, good work.
Originally Posted by Autoworks
(Post 48277800)
Originally Posted by 92egdxhatch
(Post 48277660)
Nice!
Slight boost creep?
Originally Posted by Muckman
(Post 48277880)
Slight boost creep?
Originally Posted by effin
(Post 48277869)
sweet any more specs on your setup? i assume thats your eg in your avatar?
I'm using a Garrett "57 trim", stage V turbine wheel, v-band adapter to downpipe, Tial 44mm wastegate (v-band) routed into the exhaust, Tial 50mm Blow off valve, Precision 600hp intercooler, aluminum 2.5" charge piping, 3" stainless exhaust piping to cutout. Here's a pic. Sorry for the thread jack. http://i186.photobucket.com/albums/x...2/GOPR0990.jpg |
now thats bad ass man , i saw your setup in the turbo ls thread! Not to mention you have A/C
(Post 48275139)
May I ask why such a difference on the Dyno? That's a pretty hefty swing in power on each pull.
Also, I would like to know what exhaust wrap you are using. It looks much better than most I've seen, as in better quality.
Originally Posted by nyghtstalkr
(Post 48278607)
(Post 48278462)
(Post 48278611)
