P28 on a gsr good ?
Old Dec 29, 2012 | 11:57 PM
OrtizNwk's Avatar
Default P28 on a gsr good ?
I got a gsr with b16 trans but my v Tec don't pop I heard a p28 would be good for my gsr and the vtec should open up if I get one
Old Dec 30, 2012 | 12:27 AM
racebum's Avatar
Default Re: P28 on a gsr good ?
the correct ecu for a 94-01 gsr is p72, after that you will see a01 for 94-95, a02 for 96, a03 for 97-99 and a04 for 00-01
you can use a p28 if it has a p72 map burned on it in crome, hondata etc. it's just a more expensive way to go about what you need.
first, find out what ecu is in your car and report back.
vtec not working can be from a variety of things, knock sensor, oil pressure, vtec switch or wiring along with of course the wrong ecu
Old Dec 30, 2012 | 03:31 AM
OrtizNwk's Avatar
Yea I got a p72 but my car was swapped used to have a Ls now has a gsr
Old Dec 30, 2012 | 08:50 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Then the vtec wires need to be ran. You have the correct ecu and vtec comes on at 4500 rpm.
Old Dec 30, 2012 | 11:04 AM
OrtizNwk's Avatar
I'll check it out then thanks
Old Dec 30, 2012 | 06:29 PM
98lude-t's Avatar
Sure it's not a p75.
P28 doesn't control iabs
xxdaco69xx
Apr 10, 2012 06:29 PM
jimmy o.
Nov 4, 2010 01:55 PM
92integraVTECgsr
May 2, 2009 06:09 PM
JaydmEg
24
Nov 29, 2008 02:37 PM
black-ek9
12
Apr 6, 2004 01:29 PM
