HELP WEIRD GRINDING/Rubbing noise?
Old Dec 29, 2012 | 07:20 AM
Rva802's Avatar
Icon3 HELP WEIRD GRINDING/Rubbing noise?
Hey guys so I have a 2001 acura integra gsr that has a weird either rubbing or slight grinding noise when the car decelerates. It doesn't matter what gear im in however in higher gears the noise is less noticeable. Maybe it is less noticeable because my exhaust is loud. The problem occurs when my foot is completely off the clutch and completely off the gas and the car is slowing down due to natural forces. Once I push the clutch in or pop it into neutral the noise goes away. I initially thought it was tire rub but I recently raised the car so that should not still be happening. I've been looking online and I think it's a bearing. Either throw out or wheel or something. I hope I don't need a tranny rebuild. The car has 123K miles on it. Any ideas?
Old Dec 29, 2012 | 08:34 AM
fcm's Avatar
fcm
Old Fart
Default Re: HELP WEIRD GRINDING/Rubbing noise?
I am guessing clutch related as noise goes away when clutch is disengaged.
If your still on the original clutch, it's time for a new on anyway, take it to a reliable shop have them listen to the "grinding" noise to see what they think.
Sound does not translate well in print, not much better in a sound clip or vid, you really need to be sitting in the drivers seat to really hear it. 94
Old Dec 29, 2012 | 06:49 PM
Rva802's Avatar
Thanks for the advice. It may need a new clutch but supposedly it was replaced last year. It feels fine to me when I engage and disengage. Ill go get it checked out tomorrow. But for now do you think it could be a jacked up bearing?
Old Dec 29, 2012 | 07:00 PM
10psiLsEf2's Avatar
Pilot bearing? possibly
Old Dec 29, 2012 | 07:36 PM
Rva802's Avatar
I have no clue. I've showed an audio guy that drove a prelude and he said my clutch is probably sticking, a mechanic that said there is nothing wrong when there is clearly something wrong, another mechanic that said it was tire rub, another mechanic that said it was the throw out bearing. I have no damn clue what it is. Tomorrow I'm taking it to a mechanic that races mazdas and is part of lucky 7 racing and hopefully he can let me know what's wrong.
Old Dec 29, 2012 | 07:37 PM
Rva802's Avatar
I know mazdas are rotary but he may have more information that all these other people
Old Dec 30, 2012 | 02:04 AM
Built4Battle's Avatar
that sounds like input shaft bearing.
i had a gsr tranny my homie gave me. got excited and put it in and everytime i shifted i heard some grinding noise but gears weren't grinding. best bet to tell if it is, start your car pop your hood and listen for the grinding sound around the tranny area. if your hearing it then its input shaft bearing
Old Dec 30, 2012 | 06:34 AM
Rva802's Avatar
The thing is I just got the car smogged and when they had it on the machine the guy took it up to fourth gear and when he decelerated there was absolutely no noise. That's what led me to believe it was rubbing. There are no grinds shifting gears. Only when the car slows down does it make that noise. However if it is rubbing and only when the car is slowing down it should still make that noise in neutral. And oddly it doesn't make the noise. Also if you disengage the clutch the noise stops leading me to believe its not rubbing and something more serious. It's pretty frustrating.
Old Dec 30, 2012 | 08:44 PM
Rva802's Avatar
So I took it to that guy and he said nothing is wrong with it -.- maybe it's just me but I'm pretty sure the car isn't supposed to make this noise.
Old Dec 30, 2012 | 10:21 PM
cptslow's Avatar
sorry for hijacking, but I'm actually having a similar problem.. @_@ and a honda kid told me it's the input shaft bearing and another group of honda kids told me it's my throwout bearing.. but from what I've researched, it would be the throwout bearing if it whines constantly? because that's what happened to my SR20.
the only downside is.. i have no garage whatsoever or tech know-how to do an input shaft bearing which just makes me mad i heard changing tranny fluid might help the noise go away but it's really just covering up the problem :/
Old Dec 31, 2012 | 09:16 AM
Rva802's Avatar
I changed the fluids and they also told me about synchro mesh but if it is the throw out bearing it's going to be expensive because of labor.
Old Dec 31, 2012 | 03:15 PM
cptslow's Avatar
so after you changed the fluid, was the noise any softer? or the same? a throw out bearing is like $20. and you might as well change your clutch if you're doing a throwout bearing.
Old Jan 8, 2013 | 08:05 AM
Rva802's Avatar
Yes the noise was there after. I spent 2 days taking out my tranny and replacing my clutch with a friend and I also replaced the throwout bearing. Both the clutch and bearing were all F&^*ed up and now the noise is either gone or less noticible. I recently bought the car so it was not my doing of messing up this car (just a sidenote). I was recently driving home and the check engine light came on but i tuened the car off and back on and the light doesnt come back on. I tuned up the car with new plugs, wires, fluids, cleaners, the whole shabang about 2 weeks ago and i checked the oil and there was NONE in the motor. There is no oil leaks under the car or around the motor so that leads me to believe im burning a tremendous amount of oil. On friday im going to do a compression check to see how bad the problem is but if I need a rebuild im probably just going to sell the car. Also when I took out the tranny the dude had a hole the size of a quarter in the damn intake. Its a possibility those metal particles got into my engine -_-. Hopefully I dont need a rebuild because I really like the car.
Old Jan 8, 2013 | 08:11 AM
Rva802's Avatar
Lastly, I know the car is burning oil because VTEC was cutting off at 5K rpm. The engine started to sputter and thats when i saw there was no oil and so added more oil. i had my friend drive behind me to see if the car was shooting out and smoke when VTEC was engaged because it smelled funny in the car. And to no suprise the car is shooting out a grayish smoke when you push the car. Doesnt look good
Any suggestions you guys can give me would be greatly appreciated.
MudBggn
May 5, 2022 04:44 AM
J-Willz
Honda Civic (2001 - 2005)
Jul 24, 2007 08:24 PM
LFE142
Mar 25, 2002 03:04 PM
