B18a1 Holding 90 oil pressure?
Old Dec 28, 2012 | 12:55 PM
Austin184's Avatar
Default B18a1 Holding 90 oil pressure?
i have a B18a1 swaped EG ,Eagle rods and wiesco turbo piston .The car holds 80 oil pressure on start up idle and around 20-22 when its warmed up at idle and around 70 when cruising ,But when i get on it in higher rpms it usally Goes to 90 than dumps down to around 80 .is this bad or normal for a B18 .
also im about to boost it agian should i get a oil restrictor with this much oil pressure because it would be holding around 80-85 in boost
thanks
Old Dec 28, 2012 | 01:18 PM
grumblemarc's Avatar
The Grumpiest
Default Re: B18a1 Holding 90 oil pressure?
Mine does something similar but reads MUCH higher PSI. Especially at start up (needle is pegged until operating temp). Idles at about 40-50ish. 70-80ish under 3k RPMs. Probably because I'm using a mechanical gauge. And I'm using a restrictor.
Old Dec 28, 2012 | 02:28 PM
Austin184's Avatar
i just went ahead and ordered me a restrictor 0.65 ,and i have a autometer phantom oil presure and boost gauge
ninjaturtleEG
Aug 28, 2012 10:50 AM
ProjectBB6
Sep 16, 2009 02:18 PM
r7
Aug 26, 2003 11:30 PM
TurboCX
Aug 3, 2003 06:33 PM
LonelyDriver02
Dec 6, 2002 11:25 PM
