Type R intake manifold question
Old Dec 24, 2012 | 02:34 PM
Spitz911's Avatar
Default Type R intake manifold question
This might have been covered before but l am looking at getting a type r intake mani and throttle body for around $300 and i think he is throwing in a valve cover with it.. my questions are i have a STOCK b16a2 with an intake would i see any gains with the manifold and throttle body and any performance differences? Also how can i tell if the manifold is a legit type r? I know the guy from work and he is pretty cool just dont wanna buy the same part as i already have.. keep in mind that i do have turbo plans (i already have the kit just looking to get injectors a p28 and a tune) so should i just run the mani and throttle body and get a temporary header and finish making my exhaust? Any info will be great thanks!
Old Dec 24, 2012 | 04:57 PM
MRGRIM's Avatar
R.I.P. Mark
Default Re: Type R intake manifold question
it will give slight gains
a little better throttle responce
re ID it will have P73 cast into it on the back near the brakeboost vac port
Old Dec 24, 2012 | 06:52 PM
Deetz's Avatar
Crazy Honda Guy
Actually, it will give slight loses all the way through the rpm until 8000rpm
Old Dec 24, 2012 | 10:32 PM
jbpnoman's Avatar
If you're planning on boosting, compare the length of the runners and do some research into which is better. I could be wrong, but if I remember correctly, shorter runners with boost = faster throttle response.
Old Dec 29, 2012 | 06:54 AM
Spitz911's Avatar
Awesome thanks guys! Ill keep researching as much as i can
oneprelude
Jan 1, 2009 10:40 PM
totsie7944
Nov 16, 2004 06:24 AM
tyflip2
Jul 18, 2003 07:28 PM
MotorMatrix.com
Jan 8, 2003 10:50 AM
