starting issues bad ect?
Old Dec 24, 2012 | 02:15 PM
408DB2's Avatar
Default starting issues bad ect?
Hello, i have a 96 civic with a B16A2 swap. (usdm Block with a JDM head) I believe the head is a year 92 or 93 have to double check but i know its a jdm head. Im having some starting issues when i try to start the car. At first i thought it was my main relay that was going bad but i replaced it with a new one and i am still having the same issues all fuses are fine.
I noticed that i have to wait about 5-7 seconds for the fuel pump to prime after turning the key on. if i don't wait it wont start, i have to wait till the engine light comes on and off. I also notice that sometimes when the car is cold i can start the engine fine on the first try. When it is warm it takes longer to start.
Is the ect sensor going bad? if so were can i obtain one for my b16 head is a jdm head.
Old Dec 24, 2012 | 08:55 PM
d15bvtechatch's Avatar
Default Re: starting issues bad ect?
advance autoparts has them, b16 jdm and usdm have same sensor. sounds like maybe a loose ground. check g101 on thermostat.
Old Dec 24, 2012 | 10:27 PM
408DB2's Avatar
the thermo ground is good. what other grounds can i look for???? how many are there? location?
Old Dec 24, 2012 | 10:51 PM
diesel718's Avatar
block to chassis
Old Dec 24, 2012 | 11:08 PM
jbpnoman's Avatar
I believe there are three. Block to chassis, thermo to chassis, and head/VC to chassis.
Are you 100% sure you have a B16A2 head? It did exist 92-93, but I would find the head code just to verify.
Old Dec 25, 2012 | 08:19 AM
408DB2's Avatar
Yes, the block is a USDM B16A2 because it has a vin # right under it. The head is a JDM head from a year 1993, as i read the 93 number on the left side of the head.
Old Dec 25, 2012 | 03:13 PM
jbpnoman's Avatar
That just means it was cast in 93, that isn't the head code.
Old Dec 25, 2012 | 05:50 PM
408DB2's Avatar
Were can i get the head code?????
Old Dec 25, 2012 | 08:51 PM
jbpnoman's Avatar
It should be near the date stamp you were looking at. It's usually either a letter followed by two numbers, a dash, and another number or two letters followed by a number, a dash, and another number.
As an example, the second gen B16A is a PR3-4. The 96-00 Civic EX is P2P.
crowedogg
Dec 29, 2012 03:33 PM
bungalo101
Apr 7, 2008 08:11 PM
jacobolito
10
Dec 1, 2006 06:34 PM
Fatty_1775
Nov 14, 2002 09:04 AM
