I want the horn to honk with alarm, but no alarm output
I have a 96 integra, with a Viper 350 Responder installed, I want the horn to honk in a pusle with the alarm, but this alarm doesn't have a horn honk output wire.. anyway I can wire up a relay to honk it in a pulse? I need wiring diagram for this feature
thanks in advance!
thanks in advance!
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Makr sure you diode isolate it cause if you turn on the parking lights the horn will sound solid.
Ground to #30 of SPDT relay.
#87 of relay to horn trigger lead, [gray or blue/green @ steering wheel harness].
Alarms park light output to #85 of relay, [and to park lights].
H1/12 orange [GWA] of alarm to #86 of the relay, horn will only honk if alarm is armed. 94
I use the black white wire dome light output on the alarm to the #85 and the brown siren output wire onto #86 instead of the orange wire so u don't have to use diodes
can't use that wire... I think all it does is turn on the dome light for 30seconds once armed/disarmed ..people would hate me lol
No diode is needed if the orange lead is used, the orange lead is a ground only when alarm is armed GWA= ground when armed. 94
horn lead to#87
Alarm park light output to #85
I can use this without a diode? if so I'll try thus tomorrow
On the 350 it has a relay for the starter kill, if thats being used then u gonna need diode, I never hook up the dome light output bc my truck dome comes on whenever it's unlocked so I use that
Ground #30
Horn #87
Dome light output #85
Siren output #86
When the alarm goes off it'll give u the honk honk
Ground #30
Horn #87
Siren output #86
Yes, as long as it, [orange lead] is not being used for anything else, [starer cut, window module or other sensors]. 94
It *does* have a horn-honk output -- See the manual. You can configure the siren output through programming as a (-) output to connect to your horn instead of a siren. This is how I use the R350 -- I don't have siren installed, at all.
I have a Responder 350 in a 2K Civic.
You can download the install guide here... http://www.the12volt.com/installbay/...iper+responder programing starts on page 20, the siren/horn is in Menu #2 - Advanced Features, [2-1].94
