Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Civic 2004 Cruise Control light
Old Dec 22, 2012 | 10:28 PM
narab123's Avatar
Post Civic 2004 Cruise Control light
Hi,
i use cruise control some times, today i notice that the button did not light on when push it to set cruise control on,
but the cruise cntrol function working properly!.
so it is a matter of light in the button. can i change it?
or i have to get new button!
thanks
Old Dec 22, 2012 | 10:34 PM
jdmeg6118's Avatar
Default Re: Civic 2004 Cruise Control light
Originally Posted by narab123
Hi,
thanks
Mine is the same way.
Old Dec 22, 2012 | 11:44 PM
It Wasn't Me's Avatar
Remove the lower dash cover, it's beneath the steering column.
Reach behind the dash, push on the sides of the switch, and push it out of the dash.
Remove the green bulb by twisting and removing it from its socket, and replace it. You will need to buy a replacement bulb at the dealership, an online Honda parts dealer, or get one from a parts car.
Old Dec 23, 2012 | 07:20 AM
narab123's Avatar
thanks,
so for sure ????
we can change the bulb not the whole button !cause in the shop he told me i should change the button?
Old Dec 23, 2012 | 11:06 PM
thanks,
so for sure ????
See for yourself, click here.
Illustration 7, part number 35851-S5A-A01.
Also, if you're not concerned with potentially marring the dash, you can just pry that switch panel off. You don't have to push it out from behind the dash.
Destin1
Feb 3, 2012 11:41 AM
scottinky
Jun 25, 2010 08:52 PM
Dekorum
Jun 29, 2008 10:06 AM
Del Sol Man
Oct 26, 2002 07:47 AM
JasonNagra
Feb 28, 2002 01:30 PM
